Results 1 to 5 of 5
Thread: 2008 Astra H 1.9 CDTI ?
    Jun 2004
    UK - Stoke-On-Trent
    At xmas the mrs bought me a EEEPC 900a 8.9" Laptop / Notebook.
    Biggest problem at the min it its running Linux, however ive spoken to a friend who is going to flash Windows XP Pro onto it instead, once its up and running on windows what options have i got with reading via OBD ?
    Im hoping there is something that will give me a MPH / RPM / BOOST Guages ?
    Also what GPS softwre is there for a laptop so i can get a speed camera warnings displayed onto my laptop screen ?
    Many thanks for your help.
    VIA EPIA TC 10000 1Ghz Motherboard,
    256Ram,40Gig,
    Lilliput 7" Touchscreen
    ALL ABOVE NEEDS SELLING !
    OFFERS WELCOME
    2008 Astra H Sportive SE 1.9 CDTI
    2006 Quadzilla Stinger 250e Quad Bike
    2000 Saab 9-3 Viggen Convertible
    Jun 2004
    UK - Stoke-On-Trent
    Bttt
    256Ram,40Gig,
    OFFERS WELCOME
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by PIE CJ View Post
    OBD can be done via USB. I dont think the EEE has a serial port. I know Centrafuse and RoadRunner, which are front ends, both have plugins for that. Im not 100% sure though with CF. I do know Road Runner most def has it.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    MPH and RPM are generic OBD-II parameters, therefore any diagnostic software that has gauges, would have those two. I'm not sure about BOOST. Here's a sample screen from ScanXL (by PPE):
    They also sell DashCommand, which is less expensive than ScanXL, but only includes the gauges (Brian, please correct me if I'm wrong).
    Speed camera warnings are a brilliant idea!
    Best regards,
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    Dec 2006
    Phoenix, AZ
    BOOST = Absolute Load, duh
    My apologies, Boost is of course the same as "Absolute Load" in SAE J1979. It's Mode 1, PID 43:
    Characteristics of LOAD_ABS:
    – ranges from 0 % to approximately 95 % for naturally aspirated engines, 0 % to 400 % for boosted engines;
    – linearly correlated with engine indicated and brake torque;
    – often used to schedule spark and EGR rates;
    – peak value of LOAD_ABS correlates with volumetric efficiency at WOT;
    – indicates the pumping efficiency of the engine for diagnostic purposes.
    There's also the old PID 04:
    Characteristics of LOAD_PCT:
    – Reaches 100 % at WOT/Wide Open Pedal at any altitude, temperature or rpm for both naturally
    aspirated and boosted engines.
    – Indicates percent of peak available torque during normal, fault-free conditions.
    – For spark ignition engines, linearly correlated with engine vacuum at MBT spark and stoichiometry.
    Note that hybrid engine controls can independently control torque.
    – Compression-ignition engines (diesels) shall support this PID using torque.
    Best regards,
    Vitaliy
  1. 2008 Nissan Altima Coupe Carputer Install
    By CrackerStealth in forum Worklogs
    Last Post: 01-09-2009, 03:55 PM
  2. Microsoft Streets & Trips 2008, AutoRoute 2008
    By Marvin Hlavac in forum GPS
    Last Post: 08-22-2007, 11:02 AM
