Results 1 to 2 of 2
Thread: pocket PC diag. once more...
    Oct 2006
    I saw this product:
    I asked before how to connect my USB adaptor to a pocket PC and was told it's impossible since the pocket PC cannot read USB data, so how come this device works with a pocket PC? is there a work around to make my MIO 168 work with a USB adaptor?
    Jan 2007
    This device looks like it probably uses the serial sync cable to move data in host mode.
    Although you can't directly access USB data on an external device (e.g. play MP3's from an external hard drive), I've seen Compact Flash adapters that support USB OTG. This means that you would be able to copy data from a USB hard drive TO your pocket PC, but you wouldn't be able to directly access the data on the hard drive, due to limitations on the protocol.
    However, you don't have a Compact Flash slot on your device. So, there's really no way for you to get USB to work on that device. The adapters are pretty expensive & hard to find, anyway.
  1. Using a Pocket PC
    By ashiq32 in forum General Hardware Discussion
    Last Post: 06-24-2007, 08:13 PM
