Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 21 to 30 of 116
Thread: Free OBD2 Software anyone? (No Longer Free)
  1. #21
    VENDOR - OCTech
    May 2007
    If you got it to connect at 9600 baud then your OBD device must be set to communicate at 9600 baud. The data sheet should tell you how to set it to higher baud rates, then you'll have to select that baud rate in my software.
    The instantaneous MPG is just that...MPG at that instant. If you are moving pretty fast then take your foot off the accelerator the value should spike fairly large because you are using very little fuel to go a given distance. It does get averaged by an FIR (moving average) filter, but expect that number to fluctuate. The total and trip MPG should find a steady state value the more you use the software.
  2. #22
    VENDOR - OCTech
    May 2007
    I received the ElmScan 5 today and was able to do some debugging this evening to get it to work. I rewrote part of the communication interface to the device so hopefully this will be more reliable. The new setup that I'm posting works with the Elmscan 5 right out of the box...I did not change any settings on the scantool itself.
    Remember to set the right com port and baud rate before trying to connect. Enjoy!
  3. #23
    Variable Bitrate Uraijit's Avatar
    Aug 2007
    Utah
    Quote Originally Posted by drewbp View Post
    Have you embedded this into Ride Runner yet. If so I would love to know your window name for the embed.
    Thanks.
    Edit: Figured it Out.
    Why don't people ever share the answer after they find it?
    Greedy
    -Adj.
    Anybody who makes significantly more money than you do.
    The Hoe-Puter Worklog
    Progress (Phase one):
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
  4. #24
    VENDOR - OCTech
    May 2007
    Window name is "OBD2 Monitor". I've been using opening it using the LAUNCH function.
  5. #25
    VENDOR - OCTech
    May 2007
    Anyone have a chance to try the new setup that I posted? Any feedback would be helpful and appreciated.
  6. #26
  7. #27
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    just did a quick test..good job man, she's working now!
    i'll see if i can post a youtube of her in action later...
  8. #28
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Quote Originally Posted by Uraijit View Post
    Here is the full line for the embedding of the program:
    "MyApp72","Load;OBD2Monitor.skin;OBD2Monitor;C:\Pr ogram Files\OBD2 Monitor\OBD2Monitor.exe;OBD2 Monitor"
  9. #29
    Feb 2009
    Smile
    Works like a charm! Lookng forward to see your metric option in action!
  10. #30
    Low Bitrate Laminar's Avatar
    Oct 2008
    How are you calculating instantaneous mpg?
    1999 SVT Contour
    3.0
  1. Cellphone software for Bluetooth OBD2
    By mrlate in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-02-2007, 09:13 AM
  2. OBD Free software
    By Lowtechguy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-14-2007, 05:39 AM
  3. Free USA GPS software?
    By Blue6Studios in forum Software & Software Development
    Last Post: 02-27-2006, 05:05 AM
  4. New software just like Front Row, but free
    By skizot in forum MacCar
    Last Post: 01-11-2006, 09:48 PM
  5. FYI: Awesome FREE forum software......
    By mp3pc in forum Off Topic
    Last Post: 06-13-2001, 09:40 AM
