Page 4 of 12 FirstFirst 123456789101112 LastLast
Results 31 to 40 of 116
Thread: Free OBD2 Software anyone? (No Longer Free)
  1. #31
    VENDOR - OCTech
    May 2007
    Instantaneous MPG is calculated by dividing instantaneous speed by instantaneous fuel rate. The value you see on the dashboard is also filtered by a moving-average filter to smooth out some of the fluctuations.
  2. #32
    Low Bitrate Laminar's Avatar
    Oct 2008
    Quote Originally Posted by mjo151 View Post
    Is the fuel rate derived from the injector pulse width or is it based on a stoic assumption?
    1999 SVT Contour
    3.0
  3. #33
    VENDOR - OCTech
    May 2007
    Quote Originally Posted by Laminar View Post
    It is based on stoic assumption from MAF sensor.
  4. #34
    Feb 2009
    Webster Tx
    I admit I am new to the OBDII stuff. I am using an OBDpros USB scantool. This software is many orders of magnitude more awesome than the stuff that came with the tool.
    I installed the first setup you posted a few days after you posted it. It was working great, the indicators are well placed, and all the data displayed seems accurate.
    However I did manage to finally break it a couple of days ago. I don't know how. The display is just frozen now with all zeros except the total mpg. The logs do not show up, nor do the monitored PIDs. The hex data showing up in the diag section is just scrolling 01 03: 41 03 01 00. Is that fuel system status?
    The OBDpros scantool 1.0 software that came with the tool still works. I have tried uninstalling and reloading your latest setup and the .NET 2.0 framework.
    Any help would be apprecitated, because I really like your software, and would like to use it again.
  5. #35
    VENDOR - OCTech
    May 2007
    Quote Originally Posted by babyface06 View Post
    It sounds like the software is communicating with the scantool correctly. My guess is that it is no longer monitoring vehicle speed, MAF, etc. Under the Diag page, open the PID Setup tab. Any PID's that you want to monitor should have their polling rate set to something other than zero. To change the polling rate, double click the Polling Rate cell in the grid for the PID that you want to change and enter the new rate in the editor that pops up (a screen shot is attached). I would suggest setting speed and MAF to 1 for the highest priority. The software will automatically set the polling rate to zero if it does not get valid data from a PID after a number of consecutive requests.
    I've been working hard to improve stability, enhance the UI and add additional features so that I can turn this into a pretty nice product. Hopefully this solves your problem and any feedback is helpful!
  6. #36
    Feb 2009
    Webster Tx
    Thanks! That solved my problem. I guess that problem came about, because my PC and scantool can be on without the ignition on. And, I set up your software to load during boot up. So I guess one time when I had the PC on without the ignition on, the polling must have gotten reset to zero.
    As far as feedback, I have had no problems interfacing with a touchscreen and the displays are easy to read and laid out nice.
    If you want people to nitpick, is there a way to see the data in English units on the PID monitor screen?
    And I notice that "absolute throttle position" shows up in the free software but not on yours.
    Is there a way to clear the total mpg, like if you did a mod and want to start over?
    And one more thing, have you thought of a cool name for the software, or is that a trade secret for now?
    As far as any ideas for additional features, how about being able to set a redline for RPM, mph, and temp. It could change the screen color or something if violated. I don't know about cost vs. benefit in doing stuff like that, I'm not a software guy.
    Thanks again for the quick fix! It's now working great again in my '06 Chevy Colorado.
  7. #37
    VENDOR - OCTech
    May 2007
    Good to hear that solved your problem. I will keep that scenario in mind and see if I can do something to prevent that from happening.
    I appreciate the feedback, whether good or bad.
    -I'm working on fully implementing the units so that you can select english or metric and that is what you'll see in the grid, logs, and dashboard.
    - As far as the "absolute throttle position": if this is a PID that your car supports then the software can read it and show it in the grid. Check the supported PIDs tab page...this is what your car says it supports so if it's listed in there just double click it to monitor it. Remember that the more PIDs you monitor the slower the overall refresh rate.
    - I never thought about wanting to clear total MPG but it would be easy to add. I'll put it on the TODO list.
    - Your other idea's are on my list so I plan to implement at some point.
  8. #38
    Feb 2009
    Sorry, but where can i find your soft ?
  9. #39
    Feb 2009
    i would like to down load that program u made
    if you could email me that obd2 program you made it would be great i cant find one i like
  10. #40
    Variable Bitrate Uraijit's Avatar
    Aug 2007
    Utah
    Crap, where did the download go? I finally got ready to install it, and now I can't find the link.
    Greedy
    -Adj.
    Anybody who makes significantly more money than you do.
    The Hoe-Puter Worklog
    Progress (Phase one):
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
  1. Cellphone software for Bluetooth OBD2
    By mrlate in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-02-2007, 09:13 AM
  2. OBD Free software
    By Lowtechguy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-14-2007, 05:39 AM
  3. Free USA GPS software?
    By Blue6Studios in forum Software & Software Development
    Last Post: 02-27-2006, 05:05 AM
  4. New software just like Front Row, but free
    By skizot in forum MacCar
    Last Post: 01-11-2006, 09:48 PM
  5. FYI: Awesome FREE forum software......
    By mp3pc in forum Off Topic
    Last Post: 06-13-2001, 09:40 AM
