Results 1 to 7 of 7
Thread: Is this an OBD2 interface?
    Jan 2009
    Please help!
    Nov 2004
    St Louis
    Quote Originally Posted by qewani View Post
    Please help!
    Their website says its for Toyota/Lexus/Mitsubishi cars. I can only assume it only works as an adapter for their D91 PS module. So I would have to say no, its just a small part of the entire OBDII package.
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    I wound agree with GizmoQ, Never seen one either that uses a 15pin/midi port interface.... BUT!
    Just measure the pins and see if they are straight through connections, If not at least that they all or mostly goto through the block. If this is the case, Then you just need to get a 15pin connector and have that connected to the usb/serial port... So should still be usable.
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    The Snap-On Modis 8 (very high end professional scanner) uses adapters like that for different things... just hte OBD-II one for snap-on had "keys" for it to work with different cars. So I would agree that it is part of a larger set made specifically for a certain unit.
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    At the top of the first picture, it says "25-pin extension cable", I assume it plugs into this DB25/J1962M adapter.
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    Mar 2008
    Adelaide, Australia
    I dont get why it says 25 pin when its a 15pin midi?
    Jan 2009
    mayhembdm666 & vvmaks
    in my prevoius post ,in first pic the above 25-Pin Extension Cable that is for different part not shown in that pic.
    the photo is taken from the user manual by my mobile... so ignore the above 25-Pin Extension Cable..Anyway i just want to know that can i connect this OBDII-AC-16Pin Adapter direct with my PC as an OBD2 interface ??
    the part which am talking about is here... search in the following page for " OBDII-AC-16Pin "
    http://www.autoland.com.tw/new/EN_VE...scan2_full.php
    the website discribe the part as OBD-II Diagnostic Adapter...so does that means its an iterface which connect laptop with car?
  1. New FM USB module, maybe good for our carputers?
    By skywise in forum Road Runner
    Last Post: 01-04-2011, 09:44 PM
  2. Is this an good OBD2 Interface ?
    By Centauri_dk in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-12-2008, 09:29 AM
  3. problems with obd2 interface
    By mustang_montana in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-30-2008, 12:58 PM
  4. OBD2 Source code for opto interface
    By Maddog_rvo in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-28-2005, 02:22 AM
  5. obd2 interface
    By Rita in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-09-2005, 03:57 AM
