Results 1 to 7 of 7
Thread: OBD usb connector blocking clutch
    Mar 2008
    Hi everyone,
    Recently I dipped my toe in the water and got a EOBD usb adaptor from ebay. I've since got in my car (a 2006 mazda 6 mps aka mazdaspeed6) with my laptop to try it out etc
    I connected it up without too much problems but as I went to take a spin round the block I noticed the adaptor hangs quite a bit in front of the clutch making it quite hard to drive
    Has anyone run into a problem like this? What are my options?
    I'd really like to have OBD running on my carpc so any help would be great
    Cheers
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    I removed the OBD-2 connector from its location and moved it above 3-4" further up into the dash and remounted it so I could route the wire so it didn't fall infront of the pedals. The emissions people gave me a weird look when they had to hook it up so far into the dash, but they didn't question it.
    Mar 2008
    What sort of process was involved in that?
    Jun 2004
    Westminster, MD
    Mine was simply clipped in with plastic clips, you may have to unscrew the connector though.
    Mar 2008
    Cheers for the quick replys. Will see if moving it with out busting anything is going to work after work and report back
    Mar 2008
    Mmm, not looking good as the connector seems to be stuck in place with a plastic arm attached under the dash... could cut it but I would REALLY prefer not to
    Any more ideas?
    EDIT
    Whoops forget that, turns out that arm had a clip behind the OBD port and the OBD socket comes out of the arm... should have enough cable there to relocate
    Thanks for the help melcom
    P.S if there isnt enough cable does anywhere sell the extention cables or the connectors to diy one etc?
    Newbie deanb2's Avatar
    Sep 2008
    Calgary, AB
    You can get extension cables with a right angle plug on it, so the cable does not hang down as much.
    http://www.scantool.net/accessories/...1962f-2ft.html
    http://www.obd2cables.com/products/c...1962f-2ft.html
    Dean
  1. Install Windows XP on a USB Flash Drive
    By kingofl337 in forum WinNT Based
    Last Post: 01-11-2012, 12:26 PM
  2. A couple questions about wiring up USB.
    By gthing in forum Power Supplies
    Last Post: 09-06-2007, 05:32 PM
  3. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 03:31 PM
  4. how to effectively use usb ports?
    By maloosheck in forum General Hardware Discussion
    Last Post: 06-06-2007, 11:35 AM
  5. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 02:52 PM
