Results 1 to 4 of 4
Thread: OBDII ELM Scan 327 to usb Centrafuse
    Feb 2009
    I have an Acer aspire one running xp home, with centrafuse 2.0 installed, I have the obdii elmscan 327 installed with the supplied drivers, and i cannot get centrafuse to recognize the obdii, i selected the appropriate comm port (comm port 1, which i set it to before installing centrafuse). Its at the default baud rate 9600. Im just not sure what to do to get it to work. Thanks for any and all assistance.
    Feb 2009
    I have also altered the baud rate to 38400, it seems to be a prevelant alteration that seems to work, but not in my scenario.
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    If you had an ElmScan 5, you could use STNFinder to help you troubleshoot. You can use STNTerm to try to send commands to the interface. Both utilities are here:
    http://www.scantool.net/scantool/downloads/utilities/
    Vitaliy
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    Newbie astraologo's Avatar
    Aug 2007
    Italy
    I did the setup and everything worked perfectly.
    I think the speed is 9600 baud
    mobo asrock K7S41gx- Amd atlon 1,2Ghz -512Mb ram- hd 2,5" 160Gb- lilliput 7" 619 touch-gps Holux- bluetooth digicomm palladio-usb park assist (RRPDC) -obdII elm327-hubusb trust
  1. usb peripherals work in winxp but not with centrafuse
    By manicmarauder in forum Centrafuse
    Last Post: 03-09-2008, 05:37 AM
  2. OBDII in Centrafuse and Scantool.net elmscan tool...
    By ComradeJew in forum Centrafuse
    Last Post: 03-25-2007, 12:40 AM
  3. Does trial version of Centrafuse support OBDII?
    By michbound in forum Centrafuse
    Last Post: 10-13-2006, 07:34 PM
  4. Anyone have workign VB code for elm scan?
    By infinkc in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-11-2005, 07:16 AM
