Results 1 to 7 of 7
Thread: VAG OBD in Centrafuse?
    May 2006
    Question VAG OBD in Centrafuse?
    Because i drive a VAG car, and VAG use their own protocol, which hardware and software is needed to let Centrafuse connect to my car?
    My car dont have Canbus, but i would like to have can bus support, and EOBD and regular OBD/OBD2 support.
    Best Regards
    Morten
    Feb 2009
    adding to this message, if one wants to have the gauge readout like Dashcommand, is a USB OBDII scanner sufficient? or is the vag come needed
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by mattyv View Post
    To simply get the standard OBD II supported gauge displays on software such as Dashcommand you can use the OBDPro scantool, vag is not needed - As long as the vehicle is a 1996 or newer model.
    To read the manufacturer specific data for VAG vehicles you would need to go with VAGcom.
    Paul
    OBDPro Scantools
    Oct 2008
    Quote Originally Posted by michbound View Post
    That only applies if you live in the United States.
    In Europe the date would be 2001 for petrol vehicles and 2004 for Diesels.
    Outside of the USA, Japan and Europe that date will be 2010 or even later.
    May 2006
    Hi again
    As far as i know my car dont have OBD II, it only uses VAG specific protocol, is there any ELM or alike tools that support the VAG protocol, and also OBD2, and Canbus?
    Best Regards
    Morten
    Oct 2008
    Zeecue, if you buy Vagcom (or VCDS as it is called now) you also get an interface.
    Vagcom is also capable of OBD2/EOBD with Iso-protocols and Can-bus, but not with J1850 protocols. You get 2 tools fore the price of one.
    And if i may add, 2 very good tools, far better than all the other programs that are being sold as the ultimate on OBD2/EOBD. Vag-com support the new mode 0A (or 10), and I haven't seen that on many of the others.
    For Vag-com see www.ross-tech.com
    May 2006
    We have VCDS at work, and the normal interface is just WAYYY to complicated to use with a touchscreen. and the price i WAYYY to steep for my, i just want to be able to use the free versions of Vag-Com, and maybe a DIY cable.
    The functions i want to be able to read from my own car, with a easy interface is:
    Measuering blocks, meaning RPMS, Vakuum, Throttle positions, temperatures and so on.
    Errors, and a button to delete the error.
    Best Regards
    Morten
  1. Centrafuse 2.0 Final
    By Jan_RedGTiVR6 in forum Centrafuse
    Last Post: 08-17-2008, 01:35 PM
  2. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 09:31 PM
  3. Centrafuse 2.0 RC3
    By smeesseman in forum Centrafuse
    Last Post: 05-21-2008, 10:29 PM
  4. Centrafuse 2.0 RC2
    By Ogold007 in forum Centrafuse
    Last Post: 05-21-2008, 03:59 PM
  5. Centrafuse & OBD function
    By kasprzak in forum Centrafuse
    Last Post: 09-15-2007, 07:09 AM
