Results 1 to 3 of 3
Thread: Adaptronic
    Mar 2009
    uk
    Adaptronic
    Hi
    Hope someone can help me
    I am building a project car at the moment and would really like to use the adaptronic ecu. www.adaptronic.com.au
    The ECU would be perfect for my project apart from one thing, I want to have an LCD panel to use as a dashboard. I have spent a couple of days trawling the internet looking for a device to accomidate this.
    Adaptonic sell a device called a vidigauge but the screenshots are a bit rubbish, reading on here I see the dash command which looks brilliant.
    So my question is can dash command be used with this ECU and if so how???
    or does anyone have any other suggestions???
    Oct 2008
    Seriously doubt if you can use Palmer Performance dash command. You need an ecu that supports OBD2 for that. I don't think that an aftermarket ecu will support OBD2.
    VENDOR - OBDPros
    Mar 2006
    Check with adaptronic ask them if they support OBD II, if they do then you should be able to use Dashcommand.
    Paul
