+ Reply to Thread
Results 1 to 10 of 10
Thread: Diagnostics tool for Nokia Symbian
    oxo
    oxo is offline
    Nov 2008
    Talking Diagnostics tool for Nokia Symbian
    Almost ready with DTC codes (shows in hex at the moment)
    http://apps.sourceforge.net/trac/symbtelm
    or if you have "Need for Speed"
    http://www.racechrono.com
    EDIT:
    I received info that the tool was interesting, but wasn't telling enough.
    OK: the tool works on a Symbian Nokia Telephone and connects to a Bluetooth ELM OBD-II device.
    - it will then allow one to diagnose problems when it is finished.
    Displays more than just hex now
    Read more @ http://apps.sourceforge.net/trac/symbtelm/
    oxo
    oxo is offline
    Nov 2008
    http://apps.sourceforge.net/trac/sym...WindowsVersion shows a screen shot of SymBtElm running on windows
    - at some stage I will write in serial support so it can also communicate with an ELM
    Aug 2009
    Will this work with the Elmscan 5?
    http://www.carplugs.com/obd2bluetooth.html
    oxo
    oxo is offline
    Nov 2008
    Quote Originally Posted by amwebby View Post
    Probably:
    - if the bluetooth can be connected to by your Nokia
    - and Elmscan 5 supports your car
    - and if the Elmscan used an original ELM 327 chip
    My program does not require a specific manuafacturer of an "ELM" device that uses an ELM 327 chip.
    This is the last time I answer this sort of question.
    My main hardware support is for:
    in german http://www.obd-2.de/eShop/index.php?...roducts_id=185
    in english http://www.obd-2.de/eShop/index.php?...85&language=en
    as I have one and activly fix bugs if it doesn't work.
    Any other device: ask the supplier.
    Aug 2009
    Thanks for that. I'l go for the hardware you link to, it's cheaper too!
    I have version 1.0.38 installed and working on my Nokia N78. That already has Python 1.04 instaled on it. When I tried to install later versions of Python I get a "Cannot instal, component is built in" error.
    Anything I can do to support development I wil.
    oxo
    oxo is offline
    Nov 2008
    My wife just got an N86 8M so I will see if I can install on N series
    - I usually have E series
    I seem to remember you have to deinstall old versions of python when going from "old" python to new ...
    If you are a windows user, go for the windows setup file
    https://garage.maemo.org/frs/?group_...elease_id=2763
    Aug 2009
    Ah, just spotted the "uninstall old versions of Python" stuff. Will try tomorrow. What's the latest and best version to install on Symbian V60 3?
    Aug 2009
    I'm afraid I have to report, after tryng every version of Python from 1.9.0 onwards that they all throw up the same error on my Nokia N78, "Unable to install, component built-in."
    The only version of Python I have found that works is 1.04 with SysBTElm V1.0.38
    Oct 2009
    Will it work with ElmCanII-WLAN?
    I see that you definitely support the ECII-BT-INT (ElmCanII Bluetooth Intern).. which is nice.. but I find myself desiring the WLAN version so that the iPhone app "Rev " will also work... So, is there any chance that symbtelm will work with the ElmCanII-WLAN device? Either now or sometime in the not-too-distant future?
    oxo
    oxo is offline
    Nov 2008
    Another Symbian OBD-II
    http://obdscope.urli.net/
    - works for me and does what I need
+ Reply to Thread
  1. Some dick tried to scam me with Tool tickets
    By Goofus in forum Off Topic
    Last Post: 01-24-2007, 01:52 AM
  2. USB diagnostics scan tool ?
    By n2k in forum Linux
    Last Post: 09-01-2005, 07:13 PM
  3. USB diagnostics scan tool for mac ?
    By n2k in forum MacCar
    Last Post: 09-01-2005, 06:04 PM
  4. ColdHeat Soldering Tool!
    By [iG] in forum General Hardware Discussion
    Last Post: 02-04-2005, 09:11 PM
  5. Non-working touchscreen - USB Diagnostics tool?
    By GingerPrince in forum LCD/Display
    Last Post: 09-15-2003, 05:06 PM
