Results 1 to 6 of 6
Thread: Elmscan 5 USB Question
    Feb 2009
    Does anyone know if leaving the Elmscan 5 cable plugged into the car while the car is off will kill my battery? I have noticed that when I have it plugged in and turn the car off the power light still stays on. I just want to make sure I don't leave it plugged in and end up with a dead battery in the morning!
    Thank you,
    Bill
    oxo
    oxo is offline
    Nov 2008
    Well, I have one plugged in all the time ...
    - but I start the car every day.
    I have read that people do have them connected all the time.
    Jan 2008
    Dartmouth, MA
    It seems like when the Elmscan isn't in use it uses very little power. It seems like the only thing on is the light. I haven't done a test to see how much power it actually uses, but I think you'll be fine.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    oxo
    oxo is offline
    Nov 2008
    And as a comment: if the ELM device is bluetooth, it can be it is discoverable also without the ignition off.
    I'll be investigating this latter
    http://apps.sourceforge.net/trac/symbtelm/
    Feb 2009
    Thank you guys I will try it and see what happens!
    Sep 2007
    Dawson, IL
    I do not use the Elmscan, use HPTuners for scanning/logging/tuning - had a problem where if the device was plugged in and the car was not run for around 3 days the battery would be dead.......... added a relay to switch the OBD2 power line off if the ignition is off and all is well
    If anyone gives me a rev - I give them the Bird
  1. interesting way to install XP on cd-less/floppyless
    By gospeed.racer in forum Operating System Optimization
    Last Post: 11-11-2010, 06:55 AM
  2. Quick Question (USB, IR LEDs)
    By Un_discovered in forum Off Topic
    Last Post: 04-10-2007, 02:15 PM
  3. Question on powering USB devices off of 5v line on molex connector
    By S4Per in forum General Hardware Discussion
    Last Post: 11-03-2006, 02:44 PM
  4. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 11:44 AM
  5. Lilliput USB driver CPU usage question.
    By AustnJPR in forum LCD/Display
    Last Post: 04-06-2004, 01:59 PM
