Results 1 to 7 of 7
Thread: Fuel to air ratio
    Jan 2009
    Fuel to air ratio
    I know that a vehicle trys to run at 14.7:1 but how do I calculate what the instant fuel to air ratio is? Can i use the 14.7*LTFT or something?? Any help would be great! thanks
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by jfiliaul View Post
    You need a wideband O2 sensor to know the accurate AFR.
    Jan 2009
    Ok lets say I have a wideband O2 sensor.... what pid's and calculations do I have to make?
    Also, I have a 2006 nissan titan, how do i know if i have a wideband o2 sensor and if I dont can I just get some and throw them in there?
    Jun 2004
    Westminster, MD
    Wideband O2 sensor value isn't part of the standardized OBD2 pid values. If your vehicle comes equipped with this, then perhaps you might be able to use manufacturer specific OBD requests to get this value via an interface like the mongoose, but it's not something that is documented anywhere on the internet. The manufacturers tend to keep people from posting this information.
    If you really care, you can purchase a wideband o2 sensor and controller for about $200.
    Constant Bitrate joeyoravec's Avatar
    Oct 2005
    Livonia, MI
    Quote Originally Posted by malcom2073 View Post
    Yes it is... Not all (not many) vehicles have a wideband O2 but IF they have a wideband then there's a standard way to read the voltage/current and lambda value. See PIDs $24-$2B and $34-$3B. But I agree if it's not present on your vehicle then it's easy to buy/install an aftermarket wideband controller like Zeitronix ZT-2, or Innovate LC-1 and be done.
    Jun 2004
    Westminster, MD
    Quote Originally Posted by joeyoravec View Post
    My bad
    Mar 2008
    go with the Innovate LC-1 im running one with my aftermarket fuel injction it has a lot of nice options
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 01:35 PM
  2. Milage plugin - trip meter and fuel consumption
    By festy in forum RR Released Plugins
    Last Post: 06-07-2009, 10:31 AM
  3. DIY: Built a heater for my LCD
    By nobb in forum LCD/Display
    Last Post: 10-27-2007, 01:12 AM
  4. COOL carputer with AC?
    By eduardovdr in forum General Hardware Discussion
    Last Post: 01-28-2006, 06:54 PM
  5. Air Filter and Fuel saver
    By Scorpnstail in forum Off Topic
    Last Post: 04-14-2004, 10:08 AM
