Malcolm,
Wow, this looks great!
You tried to work with me a while ago on an OBD-II plug-in for CF...and I totally dropped the ball on it. For that, I apologize. I've been so frustrated with my CarPC that I gave up on getting it to do anything but the basics...and it wouldn't always pull that off. I finally got my major USB issues worked out and it's become usable...what I initially wanted it to be.
This new version looks very nice! I'm going to try to embed it in CF. I should be able to do that as an external application.
I have a few quick questions about the skin.xml.
- The Properties type="dial"...are there other options other than "dial"?
- The "warning" and "danger" values...is that just the color-change (yellow, then red) or does exceeding these values cause an audible warning (I'm not asking because I want audible...I don't)? (EDIT: I just reread your release notes and saw where you talked about this in the v0.2 release...nevermind!)
- The "Rev="0""...any chance that causes the gauge to run in reverse (counter-clockwise)? If it doesn't a) what does it do and b) is there a way to make a gauge run counter-clockwise?
- Is there any way to make one or more of the gauges a half/partial-circle?
LinkBack URL
About LinkBacks
