Results 1 to 10 of 16
Thread: OBD 2 support for car models
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    Is there an organized list anywhere that will tell you what OBD2 sensors are available for your specific model? For example, my 2001 Hyundai Elantra will tell me my air intake temp but won't tell me my fuel pressure. Can I find out anywhere if my car is even supposed to give that data?
    Thanks!
    Oct 2008
    Here's a list of what a car may send: http://en.wikipedia.org/wiki/OBD-II_PIDs
    The keyword here is "may". It does not have to use everything from the list.
    However, anything that is not on the list will not be send out, nor will it be recognized by a scanner.
    In your case, even when there is a pid for fuel pressure, it does not mean that it is supported by the car. Most normal petrol injected cars do not have a fuel pressure sender, so the pressure is unknown to the ecu.
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    Is there a way to find out from the dealer or a specialized place which PID's my car should be sending? Basically i have a OB2 reader and I want to find out if it's working properly or if my car isn't sending out all the data.
    Thanks.
    Low Bitrate skeet2331's Avatar
    Feb 2005
    Indiana
    Download pcmscan. Use the trial version and it will tell you what PID are comming out of your car. http://www.palmerperformance.com/pro...scan/index.php
    Lilliput EBY701, M2-ATX, Intel 1.8 GHz, 1GB Ram, 160 GB 2.5 hard drive, Centrafuse, Garmin Mobile PC, GlobalSat BU-353.
    My 2000 Saturn SL2 Worklog
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    I don't have a car computer yet, this scan I'm doing is on the iPhone. Any chance someone who has a 01 elantra could run the scan? Or maybe somewhere its documented?
    If not it sounds like a matrix someone could make up, would be a helpful resource.
    VENDOR - OBDPros
    Mar 2006
    What skeet2331 mentioned would work, another approach would be to download the Pid reader from http://www.glmsoftware.com/Downloads1.aspx and it will tell you the supported pids.
    OR
    If you are comfortable with a serial terminal like hyperterm etc you can send a 0100 to the device and post back what you get and I can tell you what PID's are supported
    All of the above assume that you have an elm type OBD II reader.
    Paul
    OBDPros scantool
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    The issue with what skeet said and with the Pid reader, they both seem to require a car PC, which I don't have yet. Im looking at the OBD II data on my iPhone. So that might be my roadblock, without a car computer I'll have to get a different device to read the Pid data.
    Jul 2006
    Brisbane, Australia
    Quote Originally Posted by optikalefx View Post
    Keep searching the web. Maybe not for the iphone yet but there is OBDII software out there for the Palm Pilot. Can't remember which one sorry.
    The matter of OBDI codes seems enormously complex. There are some generic standard codes and each manufacturer adds their own to these.
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    There's already an OBDII solution for the iPhone. REV is the name of it.
    Want to:
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    I know, Thats what I'm testing.
  1. Saab OBD and Can-Bus
    By nblracer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-19-2008, 10:47 AM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  3. Brockway R2000 OBD-II Digital Multi-Gauge with NTSC Video Output (ISO9141-2 or KWP200
    By Tower Boss in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-13-2007, 08:58 AM
  4. When will ME support plug-in???
    By vbi in forum ME Archive
    Last Post: 10-31-2003, 07:39 AM
