Results 1 to 6 of 6
Thread: NON-OBD2 based gauge app?
    Oct 2008
    Hey Ive asked in a few different post but I figured Id ask in a dedicated thread.
    Is there any apps for gauges that dont require OBD2 to function? I want to use a Fusion Brain or similar device to read 5v engine sensors and then output to a user modifiable gauge program.
    Does anything like this exist? Personally I dont want to be tied down to only OBD2 data since there are alot of sensors that arent part of that data set. Things like fuel level, EGT, aftermarket wideband info ect. It would be really nice to just have sensors plugged into a dedicated controller instead of reading off an engine computer (if you even have fuel injection or if you have a standalone).
    If anyone can point me in the right direction Ill do the learning.
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Look up the Fusion Brain here on mp3car, it is capable of reading analog inputs. It would be rather simple to write a program to read that and display values on gauges.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Oct 2008
    yeah I think the fusion brain would be great for that. I was wondering if a modified front end like RR could be used to display the gauges. More or less Im not a computer programmer so making an application isnt in my skill set. I am willing to attempt it but I dont know how successful Id be.
    Jun 2004
    Westminster, MD
    I don't know about RR, but I'm working on a Fusion Brain plugin for CarPal which will display analog voltages as radial gauges and the like.
    Mar 2006
    Depends what you are running, I am using Megasquirt and there is an app that displays all the various dials you would normally get, on the pc just using the normal megasquirt comm port
    Oct 2008
    Heres the plan at the basics. For the sake of simplicity assume you have an old car, no fuel injection, on board diagnostics or any other computer controlled sytems from the factory.
    The plan is to be able to go to NAPA or whatever parts store and buy engine sensors such as a coolant temp sensor or air temp, oil pressure ect. Install those into the engine and wire them up; sensor ground, sensor voltage and sensor return. These sensors would be hooked to a Fusion Brain since this seems to be the easiest way to feed the raw data into the computer. From there the software will create the gauges and display them on the screen.
    I came up across this in Google Code which is pretty damn interesting and Im hoping maybe someone on here with knowledge greater than my own would maybe be able to give me some help on making the two talk to eachother if at all possible.
    heres a link to the code page http://code.google.com/p/memefx/wiki/gaugeintro
  1. Alpine City Cruise
    By Hell-Stopper in forum RR Skins
    Last Post: 02-22-2007, 11:05 PM
  2. What gauge wire for 800w inverter?
    By Milky in forum Power Supplies
    Last Post: 10-31-2006, 07:36 AM
  3. Fiberglassing Gauge Pod in Bezel *pics*
    By jmilin5931 in forum Fabrication
    Last Post: 10-04-2006, 09:04 AM
  4. Opus 150watt 14 gauge wire.
    By Jcarere in forum Power Supplies
    Last Post: 11-03-2005, 08:00 PM
  5. OBD2 interface based on Max232/Max233??
    By Maddog_rvo in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-08-2005, 05:11 PM
