2009 models use Can. Can is obligated from 2008 on.
Erm, not entirely sure. Whatever my car [2009 Cooper S] does by default. Next time I'm sitting in my car with my laptop I'll figure it out.
Gary (-;
OBDGPSLogger, for logging OBDII and/or GPS data
OBDSim, an OBDII/ELM327 software simulator
mp3car forums: obdgpslogger, obdsim
You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
— Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
I routinely average over 50 PIDs/sec. This is with XP on a three-year old laptop, with a 2007 Civic, ELM327 v1.3 and CAN29/500, at 500Kbaud. Speed will drop to 30-40 when the hard drive needs defragmenting. Max is about 65 when I limit the number of PIDs being monitored.
On my 2001 Accord (ISO) I seldom see anything over 15 PIDs/sec.
Some demo programs I have tried will not reach this speed. YMMV.
[IMG][/IMG]
Screenshot from a more recent acquisition - OBDPro USB.
Same vehicle, 2007 Civic LX, same laptop, just about the same, 55 PIDs/sec
[/url][IMG][url='http://www.mp3car.com/vbulletin/vbimghost.php?do=displayimg&imgid=9681']
Vitaliy,
The OBD 2007 logs don't show anything but sequential processing of the PIDs - each group of four lines is a request for a single PID and the corresponding response relating to that PID from the vehicle's ECU. The OBD 2007 diagnostic log clearly shows this - also the time stamps on each line make it simple to manually calculate the PID rate.
Regards,
M
Well, I could post a log but the files get to a large size pretty fast. You might be better served if you run the evaluation version of OBD2007 yourself.
M
