Results 1 to 10 of 13
Thread: OBDII and Centrafuse
    May 2009
    London - UK
    Hi Guys, ive bought a OBDII cable from eBay and connected it from the car to the laptop but Centrafuse didnt seem to pick it up, although VAG COM (not registered yet) ran a auto scan so it defo picked it up.
    Is there anything i need to do to get it to work? Plus can you guys suggest a good looking set of Dials Software that can be used.
    (Also an off topic question, if i buy a license for VAG COM can it be transferable? Like i want to buy it but im going to rebuild this machine so will i be able to stick it back on again?)
    Thanks in advance guys
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    I believe the default CF obd2 stuff requires an ELM compatible device, much like most of the software out there (including the gauge software in my signature). I don't believe the VAG-COM adapters are ELM command compatible, I'm not sure though.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    May 2009
    London - UK
    So i need to buy a new cable? Damn lol
    Could u suggest something cheap and cheerful?
    Many thanks for your reply
    Jun 2004
    Westminster, MD
    Quote Originally Posted by singh763173 View Post
    I THINK you will need a new cable, someone else should pipe in and answer for SURE if vag-com is elm comaptable or not...
    If you do need an ELM cable: http://www.obdpros.com/
    That's the kind I have, it works on a variety of vehicles and I've never had an issue with it. I have the serial version but I hear the USB and BT work fine as well.
    You get what you pay for, you could get a cheap $15 ebay ELM device, but it's liable to not work with your car at all.
    May 2009
    London - UK
    Mmm thanks for that Malcolm, ill wait to see if anyone else can confirm then ill decide whether to buy it if needed.
    Theres only one OBDII connector in the golf isnt there? Quite invonvieniet being above the cig lighter cos the cables cant really be hidden if there isnt newhere else lol
    Variable Bitrate csfile's Avatar
    Feb 2009
    I don't believe anyone has ever gotten around to making a VAG-COM plugin for centrafuse. A quick search around the centrafuse forum came up with this: http://forums.fluxmedia.net/obd-ii-a...-question.html
    May 2009
    London - UK
    ah nice one, i didnt know centrafuse had a forum!
    many thanks
    Oct 2008
    What model year is your car?
    May 2009
    London - UK
    its a MK4 1999 1.6SE
    Oct 2008
    Since you are based in the UK OBD2 does not apply.
    In Europe we have EOBD, which is obligated for petrol cars from 2001 on and for diesels from 2004 on.
    Probably this car does nor comply with EOBD and the elm interface is useless.
    If you buy a Vag-com (It's called VCDS now) license, the license is build-in in the adapter, and you can always switch laptops.
  1. OBDII ELM Scan 327 to usb Centrafuse
    By TRSS2 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-20-2009, 05:17 PM
  2. Centrafuse 2.0 Final
    By Jan_RedGTiVR6 in forum Centrafuse
    Last Post: 08-17-2008, 01:35 PM
  3. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 09:31 PM
  4. Centrafuse 2.0 RC3
    By smeesseman in forum Centrafuse
    Last Post: 05-21-2008, 10:29 PM
  5. Replies: 22
    Last Post: 04-15-2007, 10:38 PM
