The Brava does have a 3-pin connector for the engine. It has more 3-pin connectors which are connected to the Abs (if present), airbag, etc.
Wiring it to an OBD2 connector has no effect other than that it is easier to connect a scanner.
You cannot use a generic EOBD/OBD2 scanner, as the ecu's do not support any protocol.
LinkBack URL
About LinkBacks
), which has exactly the same diagnostic connector. The fiat probably has the Marelli IAW49F ECU, mine has the Marelli 4CM ecu, same familiy.
