Interesting ideas. Since it provides a command-line interface, I presume it talks via USB?
If you are using a usb-to-serial converter for the job, it needs to be supported on all three major platforms [linux, OSX, windows]. pl2303 or ftdi are both really good for multiple platforms IME, but I'm sure there are many many more
Gary (-;
OBDGPSLogger, for logging OBDII and/or GPS data
OBDSim, an OBDII/ELM327 software simulator
mp3car forums: obdgpslogger, obdsim
You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
— Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
So, I wrote an ELM327 simulator. It's in the same repo as obdgpslogger, the introductory post [with some of the major features listed] is here: New Toy: obdsim
I borrowed excessively from malcolm2073's code linked in this thread, so the fact that it *works* is directly attributable to him. Individual features, I'll take credit for, but the core posix voodoo is ripped almost directly from his [very readable] codebase.
Gary (-;
I am looking for some software which can Simulate all the vehicles protocols like the ECU simulators offered by scantool.net but instead i need it to work of a pc and i need it to use a obd 2 connector. Any ideas can anybody help?
cnotesdip, what kind of hardware do you have available you for this project?
Or do you want it to connect directly from the PC without any additional hardware?
Yeah i dont have any additional hardware i already use stand alone simulators but i need to use one for each protocol i want a pc software that can simulate multiple simulators
Without hardware that is going to be a bit of a problem.
PC-communication differs from Car communication on a hardware level.
I do not know of any Pc-program or hardware that is capable of simulating the J1850 protocols. So, you will need to develop some internal or external hardware that is capable of communicating with J1850 VPW and PWM.
For the can-protocol you need a can-chip and transceiver because the signals are too fast for the PC either on an internal board or in an external device.
The software of course you will have to write yourself.
Stil interested?
cnotesdip: OK, we got the message [all twenty or thirty of them]. Please stop emailing me and cross-posting on these forums, asking the same thing.
Are you asking about hardware or software? If you want to build hardware, I've no idea how to help, or why you can't just use www.ozenelektronik.com or scantool.net stuff.
If you want to build software, do you want something that simulates an ELM327 attached to something [in which case most protocol stuff will mostly be hidden and opaque], or do you want something that simulates actual ECUs? There are a few ELM327 software sims out there.
If you're trying to simulate actual ECUs, I don't know of any software to do that, and nor am I particularly interested in such a thing. What are you attaching it to on the receiving end? It seems like you want some kind of rich software thing that you can connect an OBDII reader to? What do you need that for?
Perhaps if you could explain what you're trying to achieve rather than how you're trying to do it, it would be easier to help you out.
Gary (-;
Scantool.net offers the Simulators but for each specific protocol you need to buy one, in addition to this the Simulators are very limited i need a simulator that can be able to sent out a VIN Number im using the simulators for testing on a scantool im trying to developed. What i wanted to do if possible is hook up my pc to a car using the obd connector and copy all its information like the sensors protocols vin number and so on then i could use that info to simulate the car hook it up to a scantool and test it but i dont know if this is possible. It would be nice if scantool.net made a multiprotocol simulator that you could edit using a pc.
