Other than codes I am not sure OBDI exposes the data. I *think* you have to tap into the sensor inputs yourself (or add sensors) and then us something like the FB to convert to a form that would feed the plugin.
I have an OBDI vehicle which has at least VSS, MAF, Temp, O2 sensors that feed data to the ECU. I figured I'd tap into those, feed them to the FB, and read that data, do a little math on it, and pass to obdsim via a custom plugin. Then any software I use just thinks it's dealing with OBDII from that point. We should be able to share a lot of our work this way.
For example on my vehicle with no ECU, as long as I can add sensors or generate the same data, I get to reuse everything else![]()
LinkBack URL
About LinkBacks
