Download STNTerm, then send the following commands:
ATZ
ATH1
ATSP00
0100
011C
Right click in the window, "save as" or "copy", and post here. Then, repeat with:
ATZ
ATH1
ATSP3
0100
011C
Best regards,
Vitaliy
Hello. I have a problem. I have a elm 327, i connect it to my c4 from 2006 and the soft says cannot connect unknown protocol. Can somebody tell me what to do?
Thank you!
ATZ
ATH1
ATSP00
0100
011C
ATZ
ATH1
ATSP3
0100
011C
Best regards,
Vitaliy
You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
— Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
And what are those command for? What is the purpose of this program?
The program is a virus, its purpose is to steal your private information, post it to our servers in Somalia, and then set your PC on fire.
I'm kidding. The software is a terminal that lets you talk directly to the ELM327 and your car. The first set of commands sets the protocol to "Automatic", the second set sets it to "ISO9141". Then we send two OBD requests, which ask the vehicle which PIDs are supported, and what OBD system it has.
Vitaliy
Does the same commands work for FIAT Grand Punto with 1.3 MJD diesel engine?
I get the same error as unknown protocol.
DigitalVampire, what's the model year and where (which country) do you live?
The same commands should work, but I doubt that your vehicle is EOBD compliant (unless it's MY2004+ car).
See this page for a more in-depth explanation:
How do I know whether my car is OBD-II compliant?
Best regards,
Vitaliy
I have the same probelm unknown protocol.
I make this test
ATZ
ATZ
ELM327 v1.3a
>ATH1
ATH1
OK
>ATSP00
ATSP00
OK
>ATSP00
ATSP00
OK
>0100
0100
SEARCHING...
UNABLE TO CONNECT
>011C
011C
SEARCHING...
UNABLE TO CONNECT
ATZ
ATZ
ELM327 v1.3a
>ATH1
ATH1
OK
>ATSP3
ATSP3
OK
>0100
0100
BUS INIT: ...ERROR
>011C
011C
BUS INIT: ...ERROR
I use this device
http://cgi.ebay.com/ebaymotors/AL-OB...=p4506.c0.m245
I had FIAT IDEA ELX 1.4 2007 from BRAZIL.
I try test with other software but not work too.
Thx
EMERSON VIER
I'm afraid that either your vehicles is not EOBD compliant, or the tool is defective.
Can you look at your diagnostic connector, and tell us which pins are populated?
Vitaliy
Brazil does not use OBD2 or EOBD. No rules there yet.
