Results 1 to 10 of 10
Thread: Sample fault code output required
    Jan 2009
    Just wanted to know if anyone has any sample data from a mode 3 request trobule codes function.
    I don't have access to a car with the MIL lamp on at the moment and I would like to get my head around how these codes are interpreted. The more fault the better!
    Cheers
    Simon
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Quote Originally Posted by sonicmule View Post
    Cheers
    Simon
    Here's sample output from an ElmScan 5, connected to the ECU Sim (CAN):
    Code:
    ELM327 v1.3a
    >ath1
    OK
    >03
    SEARCHING...
    18 DA F1 10 10 0E 43 06 01 00 02 00
    18 DA F1 10 21 03 00 43 00 82 00 C1
    18 DA F1 10 22 00 00 00 00 00 00 00
    18 DA F1 18 04 43 01 01 01
    What are you using for development?
    Best regards,
    Vitaliy
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    Sep 2008
    go unplug your O2 sensor. It shouldn't take long after that.
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Or, possibly less destructively, leave your fuel cap off for a couple minutes.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Low Bitrate sinclairvital's Avatar
    Jun 2005
    Fault Codes
    Hi,
    I have written and posted a document on my web site to give a few examples and explanations of fault codes responses read from real vehicle ECU's with the OBDKey vehicle interface unit.
    http://kbmsystems.net/files/Engine%2...h%20OBDKey.pdf
    The tests were carried out on Ford ECU – CAN based OBD-II protocol - and
    VW Golf, Subaru WRX, Mitsubishi Evo 8, Triumph Motorcycle ECUs– ISO 9141 based OBD-II protocols- with the OBDKey version 1.10K
    Sinclair
    Oct 2008
    Nice examples Sinclair.
    Do you also have examples of mode 0A?
    Oct 2008
    Sinclair, to answer your question, mode 0A is a new mode for reading DTC's.
    These DTC's are called "Permanent" and can only be reset by the ecu and not by a scanner. Mode 04 has no effect on these DTC's.
    The mode is defined in the 2007 version of SAE J1979 and ISO 15031, so I am amazed you never heard of it. Other programs like VCDS (or Vagcom as it was used to be called) and the Silver Scanner from the Dearborn group already support this mode in their software. Even wikipedia has already heard of it.
    See: http://engineers.ihs.com/document/ab...QIACAAAAAAAAAA
    and: http://en.wikipedia.org/wiki/OBD-II_PIDs
    Jun 2005
    Mode 0A
    Thanks for enlightening the group! Of course I had heard of it.... 2007 was a long time ago
    Do you have sample commands and responses then? Care to share?
    Cheers
    Sinclair
    Oct 2008
    Strange, below is the message I received, are you trying me out or what?
    "Mode 0A? I've only used modes 1 to 9 with OBD-II, so where would I find out more about mode 0A?
    I have used the EOBD commands, SSM commands and VAG / KW1281 commands, but I don't recall mode 0A! Can you enlighten me please?
    Sinclair "
    I've got just one question left, Why is this mode still not supported by the majority of the programs which you have to pay money for.
    I would expect an up-to-date program for the money they charge. Makes you wonder if any of the other new additions are supported.
    Jun 2005
    Could it be due to lack of sample data?
  1. Ford Transit Mk 5 Fault code reader
    By maltesefalcon in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-12-2008, 10:08 AM
  2. sample for in-car OBDII output on 20x4
    By Telek in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-23-2007, 12:51 PM
  3. XMDirect Digital Audio Output ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 09:10 PM
