Hi
I would like to know the possible values (range) of the MAF OBDII parameter (gr/sec) for a standard diesel engine.
Moreover, can someone help me to find the right formula to calculate the consumption value using the MAF parameter?
Luca
You can't calculate it for a diesel using the MAF-value.
The amount of air going into the engine is not restricted, it's the amount of fuel that's restricted.
