Has somebody tried the plx devices boost and oiltemp sensor modules and connected it to his carpc ????
I would like to know does it work OK ???
Eric.
I have their AFR sensor in my car, and have written some code to interpret the data. It's been baked into RomRaider and SSM Suite (http://www.romraider.com/ and http://www.codeplex.com/ssm) so if you have a Subaru you're in luck. If not, they're both open source so have at it.It should be really easy to add support for other sensors - just a few lines of code to do the conversion to the appropriate units.
Thank you for your answer, i have a Evo.
I want to use the boost and oiltemp because i dont like some additional gauges on the dash ore somewhere else.
