This may be a really dumb question but I have not figured it out. I have a 2001 Audi TT and the ScanTool OBDLink. I am running Centrafuse as my front end. Using the scantool software I have been able to get it to recognize the tool on Com4. But so far no readings(Plus the scantool util does not seem to like Windows 7 too Much(side issue) I need to know what setting to use in Centrafuse to get it to show up. I got it to say connected once but still no data. I am not sure if it is the order I am hooking things up on the settings.
Any help would be really appreciated. I am not looking for get the specific VAG codes but things like speed, MAF sensor, RPM that kind of stuff that would display on the default centrafuse install. I set the port to com 4 but it seems like the options are all for ELM320-327 Which one should I be using?
