Results 11 to 20 of 28
Thread: OBDII Wifi Dongles?
  1. #11
    Low Bitrate sinclairvital's Avatar
    Jun 2005
    Remote access to OBDKey WiFi
    Hi Gary
    the way it would work is that i would assign you an ip address and a port number then you can access remotely using that. You wouldn't need any OS specifics from my side.
    Sinclair
  2. #12
  3. #13
    Nov 2009
    PLX KiWi WiFi initialization issue
    Quote Originally Posted by mgile View Post
    More or less, yes, for most of the WiFi devices, the procedure is:
    1.) Connect to the 802.11 AdHoc network provided by the device
    2.) Open a socket to the IP Address that represents the WiFi scantool, which in the case of the Kiwi, you would connect to 192.168.0.10, port 35000.
    3.) Start your ELM327 command cycle (i.e. warm reset, pull protocol, supported PIDs).
    -Mike
    Hi Mike! I wrote you to you fuzzyluke support mail, I don't know if you received. BTW I write here, maybe someone else could help.
    Following your procedure everything works great: I connect to the device opening a TCP Socket (LINK led stop blinking and becomes fix), requesting and reading PID data. I tried this though iphone and using telnet through terminal on a macBook connected to the PLX (in this case no socket manual creation is needed).
    The only problem is that, if I don't send command for about 10 seconds, connection is closed: "connection lost by foreign host" and LINK led starts blinking again. I have to reboot the initialization process in order to play again with ECU.
    Here my initialization process:
    1) open TCP socket to 192.168.0.10:35000 and save input and output stream objects (OR SIMPLY: telnet 192.168.0.10:35000)
    2) start writing to output object:
    +<CR>
    ATZ<CR>
    ATE0<CR>
    OBD commands: example: 01 0C (RPM) and answer is right 41 01 XX XX.
    If no commands, connection is closed as said.
    I also tried to set the protocol with ATSP0 (auto) and ATSP3, ATSP4, ATSP5 and after that I set the wakeup time: ATSWFF (5 seconds), without success.
    Someone can help?
    Thank you very much.
    covitod
  4. #14
    Nov 2003
    Connecticut
    OBDKEY is also $296 shipped to the US.
  5. #15
    Jan 2010
    Hey guys,
    I'm interested in this stuff too.
    I was amazed to find a bluetooth obd dongle out there for $16,
    does this do what you want?
    http://cgi.ebay.com/ebaymotors/Bluet...motiveQ5fTools
    Cheers
  6. #16
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    why would someone choose wifi over bluetooth? (honest question)
    i thought it might be a price thing but they seem to be the same price....except that wifi is point-to-point so your sacrificing your internet connectivity.
  7. #17
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    I already have a bluetooth OBDKey [albeit one of the older ones, with a really low samplerate]; I was looking for a wifi one because communicating with it requires actual different code to be written [unlike the bluetooth ones, which are just serial by the time they get to userland.]
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  8. #18
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by Melton View Post
    Hey guys,
    Cheers
    Bluetooth != Wifi, but thanks for playing
    To be honest, I prefer bluetooth myself, so I am interested in hearing the answer to justchat_1's question as well.
    RevFE
    My Shop
  9. #19
    Mar 2009
    Los Angeles
    For a long time, the iphone had a hopelessly crippled bluetooth stack, so wifi was the only way to communicate wirelessly with it. I believe that that's the heritage of wifi dongles [I remember seeing devtoaster first using it and thinking that was pretty cool].
    Gary (-;
  10. #20
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Isn't it still the case that you can't use the iPhone to communicate w/ non-Apple-approved Bluetooth dongles?
    Currently the cost of Bluetooth modules is about half the cost of WiFi.
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
  1. Can OBDII dongles be found in any brick & mortar stores...
    By Nola111 in forum General Hardware Discussion
    Last Post: 03-06-2008, 05:45 PM
  2. WIFI CONNECTION MANAGERS (mini review)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-27-2007, 09:04 PM
