Results 1 to 10 of 11
Thread: Dash Command on F-650 Ford
    Dec 2006
    I have the J1939 connecter ( supposedly ) and would like to know the possibility of installing any type of OBD-II scanner on the truck to use dash command
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    Are you sure it's the J1939 connector? Can you post a picture? The last F-650 I saw (model year 2006 I think - it had the Cat engine) had a regular looking OBD-II style 16-pin connector. Unfortunately, I did not have my laptop with me at the time, so I have no idea what OBD-II protocol it supported (if any).
    Brian @ Palmer Performance Engineering, Inc.
    http://www.palmerperformance.com
    Dec 2006
    this is the connecter and its 2008 model
    I really would like to have some sort of info on the carputer
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Quote Originally Posted by topkick View Post
    Yup, that's a J1939 connector. Can you pop the dust cover?
    Sadly, J1939 is fundamentally incompatible with OBDII. Hardware is the same (CAN), but the way messages are encoded and the way communication is structured, are completely different.
    Vitaliy
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    VENDOR - OBDPros
    Mar 2006
    There are some low cost J1939 solutions available PM me and I can send you the info
    You could also look at Autotap but they are expensive!
    Paul
    OBDPros Scantool
    Sep 2008
    Quote Originally Posted by PPE View Post
    I have encountered connectors like this in some heavy duty Chevy trucks that are actually J1708 in a J1962 connector. That took awhile to figure out.
    Dec 2006
    Quote Originally Posted by Aberk View Post
    That's odd. Do they at least use the same CAN pins (6 & 14)?
    Vitaliy
    Sep 2008
    Quote Originally Posted by Vitaliy View Post
    Vitaliy
    J1708 isn't CAN, but they used the J1850 pins. Which, ironically, are the same pins that are driven by our product for J1708. I.E. our device can be configured for heavyduty or OBDII and the same pins on our cable are used for J1708 and J1850, so all we did was change the connector and it all worked.
    Dec 2006
    Sorry, I was thinking "J1939".
    Newbie funnynypd's Avatar
    Sep 2010
    Are they still using the J1708 based diamond logic toolset for diagnostic and service?
  1. Replies: 1
    Last Post: 07-31-2008, 06:37 PM
  2. closed
    By AmgAuto in forum Car Audio
    Last Post: 03-02-2008, 12:59 AM
  3. Help on custom dash for Caddy STS
    By Slaughterhouse in forum Fabrication
    Last Post: 12-14-2006, 07:47 PM
  4. Replies: 11
    Last Post: 01-02-2005, 09:33 AM
  5. In dash or Not in dash that is the question
    By belezeebub in forum Fabrication
    Last Post: 12-10-2004, 06:18 PM
