Results 1 to 2 of 2
Thread: Need help with setting with CF and OBDLink
    May 2009
    Blog Entries
    2
    I have the scantool obdlink and am running centafuse. I know it is connected to com6. I have that checked, problem is it is not connecting. My current settings are speed 9600 and type elm27.
    I also have it set with autostart on. Am I missing anything? I have tried changing the speed and just about every setting. Could someone clarify the settings and if there is a process I need to follow.
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Quote Originally Posted by obstacleman View Post
    The default baud rate for OBDLink is 38400.
    Vitaliy
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
