Results 1 to 9 of 9
Thread: Simple ODB2 Microcontroller Project, need some help.
    Oct 2009
    Hello guys,
    I have a project using the ODB2 port and a microcontroller I'm going to start working on and would love some help. The project is pretty simple, the only information it needs to get from the car is real time RPM, throttle position, and MAP sensor. Once I have that information the microcontroller has to turn on or off an electric actuator. Thus, I'm planning to use some kind of programmable microconntroller board. Prob, a development board using something like a PIC18. chip.
    What would be great is, a dev. board with an LCD to view a menu. Then control and adjust the commands.
    Any help would be very thankful, I don't have a lot of cash, but would be willing to pay someone for their help.
    Thanks,
    Fabio
    VENDOR - OBDPros
    Mar 2006
    The simplest option would be to use an ELM327 type micro that does all the OBD2 stuff for you and then integrate it with your Dev board to display data etc.
    Elektor has a number of articles on how to do this using a different chip but the concept is the same
    http://www.elektor-electronics.co.uk...er.58218.lynkx
    Paul
    OBDPros Scantool
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Electric cutouts?
    Oct 2009
    Thank you Paul, For sure I will do some reading about that link. Now, if I just want to get the information from the car such as PRM's, MAP sensor and Throttle Position, do I need the ELM327 ? Or can I just use a programmable chip ?
    Thanks,
    Fabio
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Quote Originally Posted by fab26x View Post
    Hello guys,
    Thanks,
    Fabio
    Fabio, have you had a chance to look at Microchip's development boards? I personally prefer the 16-bit parts (33F or 24H), you get a lot more bang for the buck (easier to develop on, too).
    You can start with an ELM327, or -- if you have some time -- we have an easy to use OBD module called microOBD in the works.
    Best regards,
    Vitaliy
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by Vitaliy View Post
    Best regards,
    Vitaliy
    Nice! That adds all the extra support circuitry needed for the ELM327 to talk to the car and has to be added on anyway. Plug-n-play.
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    Not sure if it'd add way more complexity, or if it'd be better for saving some money, but if all you need is RPM, TPS and MAP, couldn't you just tap into the various sensors and use just any old I/O chip? 18F2455 or an Arduino or something? Or just grab an MSD Boost Control or Nitrous Control or something? I'm guessing you're using it for one of those two things? /shrug
    Or I could be way off, and this is the start of something much cooler. Not that it wouldn't be cool regardless, I'm sure. I'll just shut up now.
    Anyway, just my two cents after tax.
    Cheers,
    Kris
    How Much Horsepower Can I have And Still Go To Heaven?
    Apr 2009
    I am having hard time with ELM237, here in Brazil, I still couldn't find a fully OBD-II compliant car... None have awnsered proppely for the $01 PID 05 request.
    Dec 2006
    Quote Originally Posted by fanl View Post
    Your best be is to test it on newer cars, because Brazil only recently adopted OBD (there's even a choice for PID $1C now, "Brazilian OBD"). Or it could be that your ELM327 is bad.
    Vitaliy
  1. 2004 Mazda RX8 macMini Project
    By mazdachuck in forum Worklogs
    Last Post: 06-21-2008, 04:17 PM
  2. New Project - Toshiba Satellite
    By ZoomVT in forum Newbie
    Last Post: 04-12-2006, 10:31 AM
  3. DIN compatable PC project
    By don-m in forum Worklogs
    Last Post: 10-23-2005, 11:11 AM
  4. FS: Lilliput 8" LCD w/ 2 Project Housings
    By migel628 in forum Classified Archive
    Last Post: 09-14-2005, 07:40 PM
  5. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
