Results 1 to 6 of 6
Thread: OBDLink vs OBDPro
    Jan 2008
    Exclamation OBDLink vs OBDPro
    What's the difference between the OBDPro and OBDLink USB scanners hardware-wise? This is what I got from comparing the two websites:
    • both have support for the same OBD Protocols
    • both are user upgradeable
    • both expand on the ELM327 (but don't actually contain the chip?)
    • both have available right-angle connectors, same cable lengths, etc
    • both baud rates start at 9600bps to 1.4Mbps(OBDLink) and 2Mbps(OBDPro)
    • both have expanded memory buffers (but to what extent?)
    • both are similarly sized
    • OBDPro is less expensive at $81.70 ($69.95 scanner + $3.00 connector + $8.75 USPS Priority to NY) compared to OBDLink at $138.60 ($119.95 + $4.95 connector + 13.70 USPS Priority)
    • OBDLink has a longer money-back gaurantee/warranty period at 90 days/3 years compared to OBDPro at 30 days/1 year.
    • OBDLink has optional bluetooth connectivity at an additional cost
    • OBDPro has ability to switch to low-power draw when PC is turned off: less strain on battery when plugged in
    So then, what am I missing? If I've made an error, please correct me.
    I don't mean to intentionally insult nor promote either party. I'm just trying to understand the difference between the two products.
    Thanks!
    VENDOR - OBDPros
    Mar 2006
    Hi Vijainair,
    I think you have a very balanced assessment I will make one correction
    The OBDPro is capable of baud rates upto 2 MBPS and so is the OBDLink (I think) I just need to update our docs to reflect that however in a number of instances the Laptop might have issues with the 2 MBPS speeds so YMMV
    Since you mentioned centrafuse I am guessing you might be looking at a carputer style usage if so one of the features that we provide is a mod that enables the OBDPro to power off when not in use leading to lower power consumption and less strain on the battery if left plugged in. This feature is not published on our site since we are about a week from offering a redesigned board however for now when customers leave a comment asking for this feature as part of the order we provide the mod at no extra cost...
    Paul
    OBDPros Scantool
    Jan 2008
    updated
    Thanks!
    -VJ
    Low Bitrate sinclairvital's Avatar
    Jun 2005
    There's a pretty good comparison done here:
    http://www.glmsoftware.com/ScantoolReview.aspx
    Aug 2008
    GLM has also posted a news item re OBDLink:
    http://www.glmsoftware.com/newsitems.aspx
    So it seems there are some connection/protocol issues yet to be resolved.....
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Quote Originally Posted by Magistertc View Post
    After repeated warnings, we banned Graham from our forum. Considering that now OBDPros is the main outlet for OBD 2007 software, his reviews are understandably biased.
    The truth is, OBDLink will reliably connect to more vehicles than any other scan tool. It is also currently the most frequenty updated scan tool, with two updates issued since its launch in August, and another update which will introduce a number of enhancements, currently pending.
    Vitaliy
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
  1. OBDlink CI - Scantool.net Product Review
    By jusjake in forum Mp3Car Blog Talk
    Last Post: 12-03-2009, 02:55 PM
  2. Firmware updates for OBDLink (1.1.0) and OBDLink CI (1.2.0).
    By Vitaliy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-10-2009, 04:17 AM
  3. Hardware review - scantool.net; OBDlink CI
    By jusjake in forum The Review Palace
    Last Post: 09-14-2009, 03:46 PM
  4. OBDLink CI firmware update v1.1.1 available.
    By Vitaliy in forum ScanTool
    Last Post: 08-14-2009, 09:28 PM
