Results 21 to 30 of 38
Thread: Looking for EOBD Pids?
  1. #21
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by fchpj View Post
    Hi,
    I am looking for OBD PIDs which can unlock doors, any car will be helpful...
    Thanks,
    fchpj
    There have been a few cases where thieves knocked the side mirror off of high end cars (I wont name names), and gained access to the can bus that way, using it to unlock doors and disable the alarm. Enhanced parameters for monitoring purposes are all we plan on indexing, too much potential for you to cause harm and hold us responsible if control parameters were given. Even if used for good, if you change engine parameters and blow your engine I don't wanna hear any crying.
    Quote Originally Posted by mezz64 View Post
    I'd be happy to help with this, just provide me with the program and some basic directions, although my Honda vehicle is from 1998, so its in the early days of OBD-II, I might not have as much functionality as someone with a later make.
    Care to share what Honda PIDs you have currently found? I'm mostly interested in fuel information, such as gas tank level, etc.
    Will do, I have to consolidate all my sources (and find a few forum threads I stumbled on before) and then i'll post a few.
    Any help we can get collecting data from you and/or others would be a great help. What OBD hardware do you have?
  2. #22
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by justchat_1 View Post
    Just a generic ELM327 interface. Vehicle is ISO 9141-2 protocol.
  3. #23
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Perfect thats what I use.... i'll put something together, test it out this weekend when i'm home with the car and if all works as planned i'll post the OBD Scanner app and we can start figuring some things out.
  4. #24
    Oct 2009
    PIDs to open door
    I am specificallly intereted in PIDs to open doors, does anyone have any information on any car about this? I also like to pay for it...
    Thanks,
    fchpj
  5. #25
    Oct 2006
    if you will publish the software, I'm sure many of us will use it & share the findings in public.
    it will be somthing like Linux Vs. Microsoft windows....
  6. #26
    Oct 2005
    westyorkshire - Fishkill NY (IBM)
    Are you planning on doing OBD1 (aldl) this sounds like a real project i can get my teeth into. its like the Smoothwall of the OBD world.
    I would like to suggest you add connector/interface types to the database to aid newbies like myself. A simple tick box to say such and such cable/interface works on this VIN.
    I am having trouble finding hardware/software to run on my 1995 Buick Riviera, it has an OBDII conector running OBD1 ALDL data. I have a cable and EFilive works but is very limited and restrictive untill you shell out 175 dollars for a licence.
    Nigel
  7. #27
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by Nigelfenton View Post
    Nigel
    The problem is theres really no way to tell....Especially during the transition years, connectors varied according to what was in stock at the assembly plant. Theres quite a few 95 cars that one month were aldl, the next month aldl over an obdii plug and two months later full obdii.
  8. #28
    Jun 2007
    Quote Originally Posted by PPE View Post
    Which LGPL libraries explicitly allow this? Even if the GPL (or LGPL) allows this (I haven't read it recently), if you use LGPL licensed code in library form, the (L)GPL does not apply to the software as a whole, but only to that specific library. Is that correct?
    In any case, nearly every diagnostics tool I have seen includes a EULA which must be agreed to in order for you to install and/or use the scan tool. Most of these EULA's have provisions against reverse engineering. I am no lawyer, but it seems to me if you take some company's scan tool and reverse engineer it against the terms of the EULA you agreed to, and on top of that post the information publicly, they may have some claim against you.
    Sorry to answer an OT old post ..
    If you use LPGL it specifically says that the end user is allowed to do a reverse engineer of the interface between the proprietary software and the LGPL'd library. The end user is allowed to modify and RE that part of the proprietary software, you cannot revoke that privilege with a EULA of any sort.
    So if you use LPGL'd code, you're allowed to reverse engineer the software, since its difficult to extract only the portions that interfaced to the LGPL'd code, then its ok to reverse the whole thing.
    Plus a lot of people confuse the library part, a DLL falls under an OK use of the LGPL, but statically linked library would mean you'd have to give out source/obj etc to allow the end user to recreate the proprietary software with a newer version of the LGPL'd code.
    If the software statically links the LPGL'd code, and doesn't give out a way of recreating the software with newer or modified versions of the LPGL'd code, then the makers are the ones in the wrong.
    This is one of the reasons LGPL/GPL software is banned at most large commercial software houses.
    You can write anything you want in a contract or EULA, it doesn't make it binding or override the law.
  9. #29
    Dec 2009
    What happened to this thread?
    Did someone get a visit from Tony Soprano or something?
    I was starting to get excited.
  10. #30
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by regulatre View Post
    Everyone loves free software....but very few people love contributing.
  1. Ford Enhanced PIDs
    By chewwtoy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-20-2015, 01:46 PM
  2. Citroen C4 PIDs
    By hypest in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-25-2011, 10:28 AM
  3. Ford CAN BUS PIDs
    By benrwin in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-25-2010, 08:53 AM
  4. Standardized PIDs versus Manufacturer Specific PIDs??
    By split63 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-04-2009, 02:54 AM
  5. Enhanced PIDs from ISO-documents?
    By RoarF in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-25-2009, 01:37 PM
