Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: Looking for EOBD Pids?
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Looking for manufacturer specific PIDs (Enhanced Parameters not DTCs)....links, references,actual lists-anything would be useful.
    Ford was easy-got all 1000+ Enhanced PIDs
    Now I need info on GM, Chrysler, Mitsubishi, Nissan and Honda.
    P.S. - This all goes to the openOBD project so every manufacturer we complete is $300 less that a person has to spend for OBD software. This is our chance to go from $500+ OBD to Free and Open Source.
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Sorry to nitpick, but... last I checked, ScanXL add-ons are only $100?
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by Vitaliy View Post
    $100 each plus $100 for the base software....last i checked $200-300 != Free
    Dec 2006
    Right, but $200 != $300, and on some websites you pay only $80 for the base software, and $80 for each add-on.
    I told you I was nitpicking.
    Good luck with the project!
    Vitaliy
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    I hope you can source some of these. I have been looking for enhanced Honda PID's for a couple years now with no luck.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    I'm considering putting together a quick "EPID" dump program to see how many we could reverse engineer. Basically you start the program hit scan, then open a door press scan again...etc. And one at a time you identify a lot of the values. Other values could be guessed by running the engine and doing a 10 sec dump.
    Figuring out what PID's are supported and retrieving the values are pretty easy-the tough part is figuring out what pids correspond to what values.
    I have a few honda PID's from various forums but someone more active on honda forums could probably do better then me.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    There might be legal issues with making manufacturer specific PIDs / enhanced PIDs publically available in open source programs.
    I would check carefully on what each manufacturer allows.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by Enforcer View Post
    Just because we don't charge for the program doesn't mean we don't have the same distribution rights as any other manufacturer. Info obtained from SAE documents for example can be used to populate the data as long as we paid for a copy and do not publicly distribute the information contained within.
    As far as the PID's go -> anything clean room reverse engineered is public information. As long as their documents are not used they have no legal basis for any complaints.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Depends, reverse engineering is quite often forbidden in T&C's
    Not saying you should or couldn't do it, just advising you to make 100% sure what you are doing won't attract the attentions of some over zealous and overpaid corporate litigation lawyers
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Do you mind sharing what you have thus far before you get shut down?
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
  1. Citroen C4 PIDs
    By hypest in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-25-2011, 10:28 AM
  2. Ford CAN BUS PIDs
    By benrwin in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-25-2010, 08:53 AM
  3. Standardized PIDs versus Manufacturer Specific PIDs??
    By split63 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-04-2009, 02:54 AM
  4. Enhanced PIDs from ISO-documents?
    By RoarF in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-25-2009, 01:37 PM
  5. Ford Enhanced PIDs
    By chewwtoy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-10-2007, 02:46 PM
