there is an adapter from connects2 that gives you the steering wheel conversion to resistance. It is only sold in EU but the company ships anywhere. I am using it right now for reverse sense power and ground and speaker input for the whole car. I have not worked out the steering wheel controls yet because i am trying to figure out which USB adapter is the way to go. Something that will read codes you will need vagcom for that.
connects2
http://www.connects2.com/c2home.aspx?AcceptsCookies=yes
Vag-Com
http://www.ross-tech.com/
LinkBack URL
About LinkBacks
