Results 1 to 7 of 7
Thread: elm327 setup
    Nov 2009
    elm327 setup
    I have an ELM327 but I am having difficulty in setting it up, yes i have a disc that came with it but no matter how carefully I follow the sparse instructions i am getting nowhere.
    Can anyone help please??
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Quote Originally Posted by jonti007 View Post
    You get what you pay for. If you bought an OBDLink or an ElmScan 5, you would have received:
    • A tested, working product
    • Easy to follow Quick Start Guide
    • Installation CD with diagnostic software and utilities
    • Best support in the industry
    If your hardware is in working order, we may be able to get you up and running with the ELM327. Can you provide more details about the problem?
    Vitaliy
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    Low Bitrate sinclairvital's Avatar
    Jun 2005
    Why not start by describing the problem you are having and what you have set up so far?
    Include the vehicle details too.
    Nov 2009
    I have Peogeot 406 HDi (90) 2001 I have had conflicting advise as to whether this model of car is OBD2 compatable with ELM327. If it isnt compatable then it is not the interface or software that is at fault, but I dont know for sure
    Oct 2008
    Peugeot diesels are not compliant, and never will be compliant to OBD2, because the car has never and will never be sold in the USA.
    It does not have to comply to the European version (EOBD) until 2004. So, it probably just does not comply.
    Nov 2009
    But a OBD2 socket is fitted to the car with 12v coming from the final pin.Why would this be???
    Oct 2008
    Socket is required by Law for PETROL cars. And it's cheaper for the manufacturer to use one type of diagnostic connector.
    The presence of the connector is no guarantee EOBD will work.
  1. pleasant experience with new setup
    By nst6563 in forum General Hardware Discussion
    Last Post: 04-28-2009, 08:22 PM
  2. What kind of setup do you have for a PCMCIA Card?
    By polo6979 in forum Wireless Communications
    Last Post: 04-18-2008, 12:36 AM
  3. Help with general setup
    By Blup in forum Newbie
    Last Post: 01-11-2008, 12:50 PM
  4. Centrafuse 1.2 won't leave setup
    By marchello2000 in forum CF Bug Reports
    Last Post: 07-03-2007, 12:18 PM
  5. Replies: 0
    Last Post: 03-20-2005, 02:34 PM
