Results 1 to 10 of 13
Thread: Get Current Gear with ODB II
    Oct 2005
    Hi all,
    i just started interacting using OBDII protocol with my car (RAV4) through a VB program i did.
    I managed to find out the standard PIDs such as RPM, Speed etc but i have not managed to find anything related to current speed.
    After some googling, i was pointed to the PID 19F5 but with no information on what mode it should be used.
    Does anyone have any idea of how to get the current gear ?
    Thanks in advance
    Chris
    Oct 2008
    Current Speed: Pid 0D Current gear is not available, only manufacturer specific.
    http://en.wikipedia.org/wiki/OBD-II_PIDs
    Oct 2005
    Thanks for the link,
    the info i found and it made me think its standard is this one
    http://obdproject.com/OBD2Info/Specs/pidlist.htm
    May be i should talk to the author.
    Oct 2008
    That's what I call an old and incomplete list. Even back in 1996 we started out with more standard pids than $1C. Any pids with 4-digit number is non-standard and manufacturer specific.
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    You could use speed and rpm to figure out what gear you're in. It would be fairly easy with a standard transmission. A bit tougher with an auto... but not entirely impossible.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Constant Bitrate firstorbit84's Avatar
    Mar 2009
    FL
    ^^^ Ya that's exactly what I was thinking. It'd be easier if you knew the gear ratios and final drive.
    Oct 2005
    Thanks for the comments,
    as a final question can anyone let me know the formula that relates speed , rpm and gear ratio ?
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Quote Originally Posted by chrisstavrou View Post
    I'm not sure that's going to work. The rpm can change depending upon engine load (up hill, down hill, pulling a heavy load) while the gear and speed remain the same. Probably get a general idea, but it's not going to be accurate under every circumstance. Besides, I thought the whole point of an automatic transmission was so you didn't have to worry about the gears?
    VegasGuy
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Spend a few minutes logging data, rpm and vss, in each gear. Draw out a chart of rpm/vss. The height at the long flat bits are the gear ratios. Write down those numbers.
    Now go back and while you're driving, pick the rpm/vss ratio that's closest to your known gear. Done.
    Of course, doing this automatically is a fair bit harder. My current plan is to [when I have time] do the ratios, use FFTs to throw away the high frequency stuff, and calculate the flat bits.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    And they say people never use higher math in everyday life. Way to go Gary.
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  2. HD Radio Commands
    By MGD in forum Road Runner
    Last Post: 07-23-2009, 04:01 PM
  3. iGuidance Hacks
    By pbarrette in forum GPS
    Last Post: 12-28-2007, 04:06 PM
