Results 1 to 7 of 7
Thread: ELM327 and Baud Rate with OBD-DIAG
    Nov 2009
    Hello.
    I have recently purchased an ELM327 interface off Ebay and have used Hyperterminal to successfully send and receive a few commands to it at 38400 baud. I would like to now use OBD-DIAG which looks like really great software with the interface. I downloaded Version 1.01.02 of OBD-DIAG but it doesn’t recognize the interface since I suspect the program defaults to 9600 baud. I only see a way to change the COM port but not the speed. Does anyone know if it’s possible to change the speed of the software (perhaps through the OBD-DIAG.ini file)? I have tried sending an email to support@obd-diag.com as shown in the “About” section of the program but the message bounced back saying undeliverable. Thank you.
    T.C.
    Aug 2008
    'support AT obd-diag.NET'
    Nov 2009
    Thanks, Magistertc. I resent the message using "support@obd-diag.net" and this time it went through. I will post back here and let the group know what I find out since it may help others with a similar issue.
    Nov 2009
    Just wanted to let the group know that I received a prompt reply back from the OBD-DIAG support group re. changing the baud rate. Unfortunately, I was informed that there is no way to change the speed from 9600.
    T.C.
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Quote Originally Posted by Techmann View Post
    T.C.
    What's your level of soldering skills? There is a pin on the ELM327 (pin 6) which switches b/w 9600 and 38400 baud, you just need to disconnect it from ground and solder it to +5V.
    The chip is a small surface mount device, so unless you have the proper tools and feel comfortable doing it, I would not risk it.
    Vitaliy
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    Nov 2009
    Thanks Vitaliy for the suggestion. Unfortunately, the unit is sealed and I don't want to void the warranty and/or damage the unit by trying to break it open.
    T.C.
    Dec 2006
    T.C.
    Probably a good idea.. However I doubt the unit is actually covered by any warranty, and the unit is relatively easy to open: peel off the label, and remove four screws.
  1. Elm327 v1.3 chip released
    By glm in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-18-2008, 06:55 PM
  2. ELM327 ver 1.2a didn't connect Lancer 1999 CK1A
    By nbctcp in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-24-2008, 08:21 PM
  3. ELM327 v1.2
    By types9 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-25-2008, 10:59 PM
