Results 1 to 6 of 6
Thread: Free Software OBD II Simulator redux
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Now with real windows support!
    Builds against mingw/msys to produce a completely cygwin-free tasty experience!
    Uses com0com to present virtual com port!
    Almost no bugs!
    Comes as part of OBD GPS Logger. Windows version only available in subversion right now.
    Disclaimers: "Almost no bugs" may or may not be accurate. Untested against build systems other than mingw. Supported ELM features "limited" at best. Untested with most windows OBDII programs. Open source and free. If it breaks, you get to keep both pieces. May turn into fleshreaper after midnight and snack on loved ones and/or firstborn.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Mar 2009
    Los Angeles
    Lots of new features. Many, many, many new features.
    Code:
    $ ../bin/obdsim.exe --help
    Usage: C:\msys\1.0\home\chunky\src\obdgpslogger\bin\obdsim.exe [params]
       [-s|--seed=<generator-specific-string>]
       [-g|--generator=<name of generator>]
       [-q|--logfile=<logfilename to write to>]
       [-V|--elm-version=<pretend to be this on ATZ>]
       [-D|--elm-device=<pretend to be this on AT@1>]
       [-w|--com-port=<windows COM port>]
       [-e|--genhelp=<name of generator>]
       [-l|--list-generators]
       [-v|--version] [-h|--help]
    The generators built into this sim:
     "Random"
     "Cycle" (default)
     "Logger"
    By default, both --elm-version and --elm-device contain "OBDGPSLogger". Some OBDII software refuses to work with devices it doesn't recognise, so I added -V and -D. For example, to pretend obdsim is from scantool.net, something like:
    Code:
    ../bin/obdsim -V "ELM 1.3a" -D "SCANTOOL.NET LLC"
    I was just now watching Rinarledge.com cross-country road trip in scantool.net's software.
    Among other plugins on the way, there's a megasquirt generator in development. There's been some OBD1 stuff before on these forums. I'd kinda like to get a vag-com one working [anyone want to donate me a VW car and a vag-com device? :-)]
    TL;DR. obdsim lets you use your favorite OBDII software with your non-OBDII car, even though that software doesn't support anything other than OBDII.
    Gary (-;
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Sweeet.
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    Mar 2009
    Los Angeles
    Current build of obdsim for windows [from just-released 0.11], here:
    obdsimwindows-2009-11-25.zip
    I'm using it with com0com, which I documented here. It probably works with Xport as well as com0com, but I haven't tried that yet.
    Gary (-;
    Low Bitrate sviyer's Avatar
    Oct 2006
    hi, can't download from the above link!
    Honda City
    Mar 2009
    Los Angeles
    Ooops! Fixed it now
    Thanks,
    Gary (-;
  1. OBD software and harware help needed
    By Bafman in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-20-2009, 07:03 PM
  2. Elmscan 5 w/bluetooth wireless obd scanner reviews
    By speedy007 in forum The Review Palace
    Last Post: 06-02-2008, 06:59 PM
  3. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  4. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  5. obd II datalogger building and software
    By backpack09 in forum Off Topic
    Last Post: 08-22-2002, 09:03 PM
