Results 1 to 10 of 19
Thread: Reading Ford ABS Data
    Dec 2009
    Hi all,
    I have a Ford focus and an ELM327 scanner. The ABS light has recently come on and was wondering if there's any software out there that is compatible with my interface and will be able to tell me what is causing the light to come on?
    Cheers
    Oct 2008
    Dec 2009
    Quote Originally Posted by p2psmurf View Post
    Thanks for that.
    How do I activate the Ford advanced features though? I can't see anywhere on the website!
    Mar 2007
    If you're just trying to troubleshoot the light- it illuminates when there's any issue with the braking system. Most commonly, this is due to low brake fluid. Top off your master cylinder and see.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Or bring it to the dealership...you'll pay twice as much buying the software as you would for the most expensive mechanic to read the code for you.
    Dec 2009
    Quote Originally Posted by CapnBoost View Post
    It's definately not low brake fluid. It's the handbrake light that comes on when the fluid is low in my car.
    Looks like i'll have to take it to a dealer as I can't find any software that tells me what the issue is!
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    Check out our ScanXL software - http://www.palmerperformance.com/pro...anxl/index.php
    Our ScanXL software supports your ELM327 interface and also has an optional Ford Enhanced Diagnostics Add-on that can read/clear ABS codes (among others) and read ABS sensor data.
    Brian @ Palmer Performance Engineering, Inc.
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    One more thing -- since you already own an ELM327 interface, you can download our software from our website and see exactly what PIDs are available on your vehicle. It will let you connect to the ABS system and will operate in demo mode until you purchase a license key. This way you can make sure the software can connect to the ABS module in your vehicle before purchasing anything else.
    Feb 2006
    Melbourne, Australia
    Quote Originally Posted by dazz25
    Thanks for that.
    Here you are
    Enjoy.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    Mar 2008
    Arizona
    Quote Originally Posted by dazz25 View Post
    All you need is hyperterminal or such. The ABS module is at $28 for a PWM or $760 for a CAN system. Send a mode $22 request for DTCs with PID $0200 and if it comes back more than zero, then get the DTCs with a mode $18 request to the ABS module.
  1. Replies: 7
    Last Post: 04-06-2009, 05:14 PM
  2. Clarification: PC ABS
    By fnkelton in forum Fabrication
    Last Post: 07-06-2007, 08:12 AM
  3. FAQ: Glossary of Terms
    By Bugbyte in forum The FAQ Emporium
    Last Post: 11-07-2006, 05:00 PM
  4. 100% ABS LCD install with texture
    By Snootch in forum Fabrication
    Last Post: 07-11-2005, 03:16 PM
  5. Replies: 7
    Last Post: 07-01-2005, 04:29 PM
