tgpfarm,
I have been doing some sniffing on the Hyundai's recently specifically a friends Santa fe, and a lot of the body controls are still on a specific ISO line that is not OBD II, not sure about the 2010 but I would suspect you might have the same situation.
If you get the right angle cable then you can switch the pins internally to allow communications on the ISO bus also if you decide to hack away at the various buses. Some of the data like door status etc might also be on the can bus...
Paul
OBDPros scantool
LinkBack URL
About LinkBacks
