Results 1 to 10 of 15
Thread: Remote Starter for my 01 galant
    Nov 2009
    Hey guys. i know this is probably a wrong place to ask, but does anyone know a nice, cheap remote starter i can install by myself into my 2001 galant?
    Free Microsoft Points
    Free WoW Time Cards
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Nov 2009
    Quote Originally Posted by Crinos View Post
    I don't want to control my car with my cellphone, i just want a remoter starter.
    Sep 2005
    Australia
    There are a ton of them on eBay. All remote staters are universal so they will work with all cars. I'd suggest getting the 2-way type as you get a verification when your car has stated, in case it's not in your sight.
    Mod - all of it. SapporoGuy's Avatar
    Aug 2009
    SonyLand
    yeah, ebay has stuff but then you have problems finding the harness to slap it in.
    Over here in J-Land we just buy the $90~$200 starter and pay another $40 for the harness. Install is dumb simple ... errr, beyond setting brake tap-tap procedure.
    Strapping the hardware down takes the longest if you are not into ripping out the dash for a cleaner install.
    Actually, just in the process of moving my old starter to my new (used) car. Harness was only $36.
    Aug 2009
    SonyLand
    ugh, forgot to add.
    1.) immobilizer or not ...
    2.) normally can't / shouldn't install in a manual shift. If you do you have to get the optional ring that checks if you have left your car in gear or not.
    Constant Bitrate popi79's Avatar
    Sep 2006
    Imobilizer...
    I had a Mitsubishi some time a go and the manual stated that if immobilizer equipped remote start is not compatible...
    This works by detecting the keys transponder in the key hole or near it. I wonder if the car will start by somehow keeping the key near this places somehow so the computer will recognize like a legit start attempt.
    "Most of the users you'll see in this site are still learning specially me"
    Aug 2009
    SonyLand
    I did go to the effort to buy the immobilizer box for a Grand Cherokee I used to have. Problem was that you need to put a spare key in it so that the sensor can recognize it.
    At the local shop (I'm in Japan) they were selling immobilizer enabled starters. I'd be more than willing to ask but I'll need to know a bit more about the car to ask meaningful questions.
    May 2007
    Quote Originally Posted by popi79 View Post
    This works fine on vehicles that use resistors in the keys, but keys with transponders, it will not. The cars security system is a little smarter than that. After you remote start the vehicle then put the 2nd key in the ignition, the sec sys. senses that there are 2 keys.......there shouldnt be. After you shut off the car, it will not restart until the sec system is reset.
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by SapporoGuy View Post
    Hear hear!. I have a car with a standard transmission, and if it didn't have a neutral safety switch I would've never installed the remote start. Several times I've remote started the car, then walked outside to find it not running, only to find it is in gear. Thankfully it won't start in gear because of the switch. If your car is manual, ONLY do it if you have or install a sense switch.
    RevFE
    My Shop
  1. 800x480 on intel 945GM/GMA950 - is it possible?
    By WiCKeD 5.9L in forum LCD/Display
    Last Post: 12-14-2010, 09:00 AM
  2. XM Direct protocol, Need help with commands !!!
    By Cinfraco in forum Car Audio
    Last Post: 07-28-2007, 05:10 AM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  4. remote pc starter
    By oddcomp in forum General Hardware Discussion
    Last Post: 08-26-2003, 09:17 AM
  5. ps2 pelican remote w/ creative reciever & girder
    By ShinkunoNamida in forum Input Devices
    Last Post: 04-26-2003, 02:00 PM
Tags for this Thread
