Results 1 to 7 of 7
Thread: Bluetooth ELM327 interface
    Oct 2008
    Hello everyone...last week I've gotten the bluetooth ELM327 interface with the software on a cd...VitalScan...after many attempts to connect to VitalScan no way...I tried all possible combinations bluetooth serial port and nothing...gives me "timeout error "...then find another soft...the Digimoto5 detect the ELM327 (v1.2) but I do not read anything on the car...this also gives me error connect...ScanTool, Dashcommand, PCMScan.
    Why dont read the car...I do wrong or forget to configure?
    My car BMW e46 330D (year 2003)
    Greetings and thanks
    Oct 2008
    You are not doing anything wrong. The car probably is not EOBD compliant. Didn't need to be until 1st January 2004.
    Find a compliant car to test the interface. Any petrol after 2001 or diesel after 2004 - as long as it's a normal passenger car and not a van.
    Oct 2008
    I read that the ELM327 bluetooth is a multi-protocol and support
    • Supports ISO 9141, KWP2000
    • Supports SAE J1850
    • Supports CAN busmy car use the ISO 9141/2 protocol
    I read it "OBDII Generic Communication Protocols by Manufacturer [Revised Feb. 17, 2003].pdf" and I see that my car use a ISO 9141/2
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by HugoCar View Post
    Supports SAE J1850
    The document you are referring to, only applies to vehicles sold in the US.
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    Oct 2008
    Which country do you live?
    Oct 2008
    I'm from Spain and I bought my car in Germany
    Oct 2008
    Car does not have to comply to the EOBD-rules, which are only required from 2004 on.
    Try it on a compliant car like I said before.
  1. Bluetooth
    By ssteger in forum VaultWiki
    Last Post: 10-19-2009, 02:52 PM
  2. headunit with built-in bluetooth
    By skeurton in forum Wireless Communications
    Last Post: 10-29-2008, 12:20 PM
  3. Centrafuse 2.0 Final
    By Jan_RedGTiVR6 in forum Centrafuse
    Last Post: 08-17-2008, 01:35 PM
  4. Bluetooth Dongle Not Working correctly
    By KingsDude in forum Wireless Communications
    Last Post: 05-17-2007, 02:30 PM
  5. timeouts and bluetooth audio randomness
    By numbers in forum PhoneControl
    Last Post: 01-09-2006, 04:44 PM
