Results 21 to 30 of 35
Thread: OBD2 works with the car off not on?
  1. #21
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I'm wondering if you just got a defective one. Probably not easy return and get another one? Is it that little aluminum square one? That's the one I've been using that says ELM v1.5a on it which means it's a knock-off.
  2. #22
    Dec 2005
    Perth, Australia
    Yep that's the exact same one. If it was defective then it wouldn't have worked on the i30 so I can only guess its fine so to speak.
    Can I assume the ELM chip in in the metal box? So I couldn't bypass the Serial > USB interface by just plugging in the COM port straight to the laptop? Obviously if the ELM chip is in the metal box that won't work.
  3. #23
    Mar 2004
    Florence Yall, BFKY
    Oh, mine's straight USB. Sure, you should try the serial. Eliminate at least 1 more possible thing.
  4. #24
    Dec 2005
    Perth, Australia
    I'm afraid of it being wired differently and frying the COM port/PC by sending 12V down it... Does the OBD port send out 5V or 12V?
  5. #25
    Mar 2004
    Florence Yall, BFKY
    The USB to serial adapter works the same as a serial port and the data lines are 5-15V depending on how it's designed, and they aren't designed very well having only 5V to work with. So the serial port on your PC is designed to handle 15V and probably does it better.
    The OBD-II port is unregulated 12V and supplies power to the electronics in the EML interface, but that isn't connected directly to the serial port side.
  6. #26
    Dec 2005
    Perth, Australia
    Ok well I just popped the metal casing apart on the serial to USB and it contains the chipset needed for the ELM so I can't just plug the serial straight into the PC.
  7. #27
    Mar 2004
    Florence Yall, BFKY
    Does it look like this?
    http://www.nandtek.com/UploadFiles/ELM327_USB.jpg
    If so, don't plug that DB9 directly into the PC. Sorry I was thinking you had a serial ELM with a serial to USB adapter. That's not a serial port.
  8. #28
    Dec 2005
    Perth, Australia
    Yeah that's the one, and yes I definitely know now not to plug it straight in
    Seems like we are out of things to try now :'(
  9. #29
    Mar 2004
    Florence Yall, BFKY
    Yeah, I think so. If you had a DMM you could see if the volts are different between the cars. It could just be going too high for it, but the power goes directly to a 5V regulator so it shouldn't have a problem. There's something a little screwy about the electrical system.
  10. #30
    Jan 2010
    FWIW, if OBD-II data is flowing with the vehicle off, the ECU probably doesn't need a reflash.
    If the problem occurs even when USB is connected to a laptop running on battery, it probably isn't a ground loop.
    I'd look at the OBD-II connector in the vehicle and see which pins are populated. Presumably, the OBD-II adapter has circuitry for all three common electrical interfaces, but non CARB regulated vehicles sometimes use other pins in non standard ways. If the vehicle is putting a voltage on one of the other pins, it could easily hang the little CPU in the adapter or trip the fault protection in the laptop USB chipset.
    -jjf
  1. Replies: 13
    Last Post: 06-22-2009, 08:23 AM
  2. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 12:42 PM
