Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
Thread: OBD2 works with the car off not on?
  1. #31
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    There is an easy solution.... take the car to a dealer that can use their scanner on the car while it is on. Then if the scanner does work, trash that unit and get one that is known to work. The one I have is a OBD2 Pro unit. http://www.obdpros.com/. That will eliminate 100% of the headaches. I Had the same exact one you had before, and it just seems that with different people they break down different for no reason. Its obviously a very cheaply built product and the fact you have issues proves it.
    PS: I have the serial port model because the previous USB model (the one you had) made me think that the USB was an issue. I recommend getting the USB, since alot of boards are starting to phase out com ports. As of now I am having to use a serial to USB adapter.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  2. #32
    Dec 2005
    Perth, Australia
    Yep I don't doubt that its cheaply made and I never 100% expected it to work, but I'll just have a chat to my mechanic next time its in cheers
  3. #33
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    It's not really a poor design. They use quality components and don't skimp on parts. They actually go kind of crazy with overuse of components like transistors to drive the LEDs, and caps everywhere. Total waste of the back side. I've studied a few things like this. And yes, inside it says ELM327/[V1.2]. LOL But I'd say it's a mass produced copy of someone else's design.
  4. #34
    Dec 2005
    Perth, Australia
    And there she is heh.
  5. #35
    Jan 2010
    Quote Originally Posted by ZX1Cruizer View Post
    The problem with this is that dealers often use make/model specific tools, not generic OBD-II ones. So, working at the dealer is not nec. an assurance that just swapping tools will fix the problem.
    The scanner at an independant shop would be more of an apples/apples test.
    -jjf
  1. Replies: 13
    Last Post: 06-22-2009, 08:23 AM
  2. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 12:42 PM
