Results 1 to 6 of 6
Thread: what is Hilux OBD protocol? kwp2000? or others?
    Dec 2007
    Question what is Hilux OBD protocol? kwp2000? or others?
    Anybody can tell which protocol Hilux(toyota) support, It is KWP2000, ISO9141, or others? will Hilux support J1979.
    Thanks for your answer.
    Oct 2008
    It all depends on the model year, the type of fuel (petrol, diesel) and which part of the world you live in (Usa, Europe, Japan or the rest of the world).
    Does the car have the required 16-pin connector? Which pins are in this connector?
    Jan 2010
    Quote Originally Posted by p2psmurf View Post
    Even that is no guarantee. In Japan, the connector will often be there, but it runs a tweaked version of the protocol and you need some weird unlock codes to get the module's to respond.
    In the EU it will generally be either ISO 9141 or CAN, depending on model year and fuel type. In North America, I'm not sure. The 'Tacoma' generally follows the US regulatory requirements, but I'm not sure about units built/sold as a 'Hilux'.
    -jjf
    Dec 2007
    it is have a 16 PIN connector
    Thanks for your reply.
    The vehicle have a 16 PIN connector. PIN 4,5,7,9,12,13,15,16 is available.
    Which protocol would this model use?
    Oct 2008
    Pins suggest ISO9141-2 or KWP2000. Whether or not the ecu actually supports the protocol depends on the rest of the question. Model year, fuel type, location.
    Jan 2010
    I'd bet that 7/15 are electrically K and L lines, but with 9, 12, and 13 stuffed, I'd generally expect J1979 *not* to be supported unless there is a regulatory requirement.
    -jjf
  1. Help Determine Vehicle OBD Protocol
    By 06Titan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-18-2009, 01:51 PM
  2. OBD II / CAN protocol
    By guy7373 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-28-2009, 04:44 AM
  3. OBD II connector on an OBD I car
    By HearseNurse in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-23-2009, 10:52 AM
  4. Saab OBD and Can-Bus
    By nblracer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-19-2008, 10:47 AM
Tags for this Thread
