Results 1 to 9 of 9
Thread: Reading VIN using ELM327-based Tool
    Mar 2010
    Hi,
    I am using an ELM327 scan tool from OBD2AllInOne. This tool is interfacing with an application that I have working for the most part. The only data I cannot read from the vehicle is the VIN using the "09 02" PID. I tried sending the command on two different vehicles and got the following:
    2000 FORD VAN
    > 09 02
    NO DATA
    2004 BMW X3
    > 09 02
    7F 09 12
    The code I have written works with an OBD Simulator (as expected). Is there something that I am missing in order to get the VIN ASCII bytes?
    Thanks in advance.
    Jan 2010
    First, it is important to remember that mode 9, item 2 is not mandatory. You can check if it is available with mode 9, 0.
    Second, the response will depend on the protocol. A 2000 Ford is probably J1850 PWM. In this case, VIN will be retruned as 5 packets, which are simply broadcast.
    The newer vehicle might be CAN. In CAN, you get a single response for VIN query, but it uses flow control. A CAN packet caries a max of 8 bytes, so instead of the whole VIN, you'll get a few bytes. Basically the first one indicating that it is a FC, or flow controlled message, and the other rounding out total byte size.
    The rest of the message won't come until the host sends a FC message in response. You can ask for a packet at a time, or basially send a buffer size of 0, in which case the ECU will send all the remaining packets one after another.
    I don't have the spec in front of me, but that is what your second example looks like - the beginning of a flow controlled message.
    Good Luck,
    -jjf
    Mar 2010
    Thank you very much! This is extremely useful information.
    Oct 2008
    7F is Negative Acknowledge. 09 is the function on which the NAK is given.
    Jan 2010
    Quote Originally Posted by p2psmurf View Post
    This is most likely correct. When I glanced at it I took it as an ID, but it is just a byte.
    But the generalities above remain true: It isn't required, and you'll get a different type of response depending upon your protocol.
    -jjf
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Are you sure the protocol is not hard set? Issue the following commands, then copy/paste your results here:
    AT SP 00
    0100
    011C
    0902
    What type of simulator are you using?
    Best regards,
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    Mar 2010
    Hi Vitaliy,
    Thanks for your response. Here is the data you asked for:
    ELM327 v1.3a
    >at sp 00
    OK
    >0100
    SEARCHING...
    41 00 BF 9F F9 90
    >011C
    41 1C 01
    >0902
    7F 09 12
    I am not sure of the name of the simulator. However, it is running on a Windows platform and the title is "ECU Emulator 1.0". It doesn't support all the PIDs but it was useful in getting my application started.
    By the way, thanks to all that have replied so far...
    Oct 2008
    Try reading 09 00 first to see what is supported.
    Dec 2006
    Phoenix, AZ
    It wouldn't hurt, but obviously the VIN is not supported.
  1. OBDroid, Android based bluetooth OBD2 scan tool
    By malcom2073 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-21-2011, 11:10 PM
  2. ELM327 v1.2
    By types9 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-25-2008, 10:59 PM
  3. PC based scan tool or handheld
    By edvan22 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-08-2007, 02:40 PM
  4. Replies: 7
    Last Post: 07-01-2005, 04:29 PM
Tags for this Thread
