Results 1 to 10 of 14
Thread: i need OBD2 circuit for renault
    Mar 2010
    wth stmatic and layout and cod file for pic that use in circuit
    tanks
    Oct 2008
    Which model year is the car and what type of fuel does it use (petrol or diesel)?
    Mar 2010
    my car renault clio 1.4 model year is 2004 auto
    (petrol fuel)
    this is OBD2 conceter of my car
    Oct 2008
    O.K. a bit of hair splitting, but your car is not OBD2 compliant. That's only used in the USA and Canada. In Europe it must comply to EOBD, which is a good thing, because under EOBD the fault lamp does not go on as quickly as under OBD2.
    It looks like the connector is up side down and you have pin 7 and 15, which means the protocol is either Iso 9141-2 or Iso 14230. Both use the same interface.
    If you search the internet you will find a lot of schematics, but I think you can buy one for just a little more. Don't buy cheap chinese clones, they usually don't work.
    Prices are around 100 US dollar, which usually includes software to read the engine and automatic gearbox.
    If you also want access to Abs, Airbag and those kind of things, you need a professional aftermarket scanner, which are a lot more expensive.
    Mar 2010
    tanks for you
    but i look for make scaner for Iso 9141-2 or Iso 14230. interface. i search internet and i found this obd-2_universal_cable
    but i not have hex file for this pic that use
    do you have it
    tanks
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by p2psmurf View Post
    I don't mean to nitpick, but you probably meant to say "ISO 9141": ISO 9141-2 ("part two") is by definition OBD-II.
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by nodey View Post
    tanks for you
    do you have it
    tanks
    It's the BR-3 interface, available from:
    http://obddiagnostics.com/
    This DIY interface is ELM327 compatible, which means you will have a wider choice of software:
    http://www.obddiag.net/allpro.html
    Our company makes the OBDLink:
    http://www.obdlink.com
    It's not cheap but is a bargain for what you get. It is available from MP3Car store for less money.
    Vitaliy
    Jan 2010
    tanks for you
    Unless I am misreading the connector it image, it looks like you have two data pairs populated, 6 & 14 and 7 & 15.
    The schematic you posted will do ISO 9141 and J1850, but not ISO 15765 (CAN bus), which I suspect this vehicle primarily supports.
    -jjf
    Dec 2006
    Phoenix, AZ
    You're right, the CAN pins are there, but I think most of the time ISO takes precedence over CAN for OBD.
    Jan 2010
    Quote Originally Posted by Vitaliy View Post
    No, the only requirement is that only one transport respond to OBD-II requests. You'll see it both ways. On a newish GM, you'll have both J1850 and CAN, but only CAN will respond to OBD-II requests. On a some BMW's just a little older, you'll find both ISO and CAN, but only ISO will respond to OBD-II requests.
    In this case, since it is a Renault and pin 1 is populated, my guess is that J1979 or EOBD is probably going to be CAN (if supported at all).
    -jjf
  1. Tank Circuit
    By ssteger in forum VaultWiki
    Last Post: 10-14-2009, 05:03 PM
  2. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  3. OBD2 Code: PO135: Oxygen Sensor Heater Circuit Malfunction
    By candlectj in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-08-2007, 08:30 PM
  4. Replies: 4
    Last Post: 08-15-2006, 09:20 PM
  5. Need help reading ring generator circuit
    By Crashless in forum Hardware Development
    Last Post: 02-21-2005, 07:19 PM
