Reply is 41. Or 65 in decimal. Minus 40 is 25 degrees Celsius or 77 degrees Fahrenheit.
You are converting it correctly. What's the coolant temperature at that moment? They should be (almost) equal. If you disconnect the air temp. sensor what reading do you get then? I have seen examples where a replacement (calculated) value was given in stead of the actual sensor temperature.
Possible sensor fault or software bug in calculating OBD2 value.
LinkBack URL
About LinkBacks
