always on
Hello all:
Is the 12VDC signal on the OBDII connector always on or is it switched with the ignition key?
If not always on, then is it determined by manufacturrer or make and model?
Thanks for your help...![]()
always on
openMobile - An open source C# Front End (why choose openMobile?)
- Always Recruiting Developers -
Like what you see? Donations are always welcome
Unfortunately, not true for all vehicles.
There seems to be no rhyme or reason to it. Very often the DLC shares the fuse with the cigarette lighter. So if your cigarette lighter has power when the ignition is off, most likely the DLC does, too.
Vitaliy
You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
— Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
