Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Audi A4 OBDII Protocol?
  1. #11
    Sep 2005
    Australia
    A while back I made up a VAG-COM compatible serial cable for a friend. Its actually quite easy to make and from what I remember the cable available off the net requires a certain version of VAG-COM software to work.. This should give you a head start. I managed to re-calibrate the throttle body and worked out the dash gauge test sequence. I didn't monitor the serial commands but im sure its quite easily done with a serial analyzer or logic analyzer.
    -Hope this helps.
  2. #12
    Mar 2010
    NZ
    No Luck :0(
    Well,
    Went into Subaru service today. They hooked up the ECU to the factory diagnostic system and it appears my ECU is completely stock and not modified in any way.
    We also tried dash command on 2 other legacy's while i was there, one newer, one older.
    The older Legacy worked 100% while the newer Legacy wouldn't even establish a connection.
    It appears at this stage that dash command doesnt support Subaru's (or at least Legacy's) past about 2003. I have however contacted the PPE techs again and I'm still hopeful of coming up with a solution and getting it working. It's a fantastic little program!
    If your Audi has definately been re-flashed then I suppose it's possible that it could be causing you issues.
    Anyways, good luck for getting it working. Hopefully it won't take too much
    PB21
  3. #13
    Newbie NZHawk's Avatar
    Feb 2010
    Interesting. I cant wait to see if my cable is causing me problems.
    I dont see how a modified ECU is to blame though, they only change a few parameters no ?
    Did you take any pics of DashCommand working? :P
  4. #14
    Mar 2010
    NZ
    No I didnt take any photos but there is a video on youtube showing it working.
    [media]http://www.youtube.com/watch?v=zQplsXqmaMk[/media]
    Personally i wouldn't have thought a re-flashed ECU would be the problem either but the PPE techs suggested that as a possible cause so yeah........don't really know.
    Anyways good luck
    Look forward to hearing if you get it going
  5. #15
    Feb 2010
    @Civic Modz
    How did you create the cable? any pics/guides?
  6. #16
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Looking at the DLC, pin 5 is missing. Since OBD-II/EOBD requires that it be present, the car is not EOBD compliant. You may be able to hack the ELM to do what you want, but a VAG-COM cable/software bundle is likely to get you the info you want, faster.
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
  7. #17
    Feb 2010
    Oh ok.
    With the VAG-COM cable, do software like DashCommand work? *Crosses Fingers*
  8. #18
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by NZHawk View Post
    Oh ok.
    Unfortunately, no.
  9. #19
    Feb 2010
    Dammit.
    Thats gay.
    The main thing I was looking forward to from my carPC was the gauges! lol
    Hmmmmmmmmm. Damn!
    Do palmersoft plan to implement it?
  10. #20
    Feb 2010
    Right, so my Cheap Chineese VAG-COM Cable arrived (Bought from ChinaVision :P Link to product here)
    I used the VCDS Lite to find the cable and it worked. I could read my error codes and check the live data.
    Now I need to try and get the full version of the software, OR find some other software that will read the data (Free)
    OR,
    Try figure out how I can access the data directly, and maybye create my own program in VB, C# (I know both these)
    Does anyone know hoe I would go about trying to get the data from the cable?
  1. ELM327 and 97' Audi A4 Quattro
    By NZHawk in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-07-2010, 05:35 AM
  2. Audi A4 1.8T B5 1997 OBDII Compliant?
    By NZHawk in forum Newbie
    Last Post: 02-25-2010, 04:11 AM
  3. Replies: 0
    Last Post: 07-08-2008, 01:56 PM
  4. 2005 Audi A4 with Symphony Bose audio question
    By atekind in forum Car Audio
    Last Post: 02-18-2007, 07:25 AM
  5. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 08:15 AM
Tags for this Thread
