Results 1 to 4 of 4
Thread: Get current gear for mercedes?
    i00
    i00 is offline
    May 2010
    I am making some software for my car and was wondering how to get the current gear that my Mercedes is in.
    Does anyone know how to get this ... or even better get a table like the one here:
    http://en.wikipedia.org/wiki/OBD-II_PIDs
    that contains Mercedes specific commands?
    Kris
    Oct 2008
    Current gear is not a defined pid in EOBD/OBD2.
    If it is available then it's Mercedes specific.
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    As p2psmurf says, current gear isn't available. That doesn't mean you can't guess it though.
    Drive in first gear for a while, storing VSS and RPM. Then drive in second gear gear for a while, storing VSS and RPM... etc.
    Dividing one by the other gets you a ratio that is effectively a gear. In future, to figure out what gear you're in, just calculate the current ratio and see which of your ratios it's currently closest to [say, within 15%]. If it's not close to any of them, you can assume you're out of gear or something.
    I've been looking at how to do this programmatically for a while. Turns out the ratios just ain't that clean most of the time. For example, here's a plot of vss/rpm for me, going from a stop all the way up to freeway speed in sixth gear, going past time traffic lights on the way:
    Note that in essence, there's graph-wide a "flat bit" at each gear; if you can get a good estimate of the value of that flat bit, you're good to go. Note that due to sampling wibbles, you can't get the instantaneous RPM *and* VSS simultaneously, which is why the graph isn't properly flat.
    The application you see there is actually a tool to filter data based on fourier transforms that I wrote to experimentally see if I could flatten the flat bits. It turns out to suck for this data, but the tool's still pretty useful for graphing things and molesting other data [I have some friends that are using it to clean up various other types of data, now]. It's called obdfft; it's open source, in the obdgpslogger package :-D
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    i00
    i00 is offline
    May 2010
    I know it would be specific to the manafacture ... most cars you can get it using extended pid's
    Kris
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 01:35 PM
  2. HD Radio Commands
    By MGD in forum Road Runner
    Last Post: 07-23-2009, 03:01 PM
  3. Replies: 231
    Last Post: 10-26-2007, 04:41 PM
  4. Amps, watts, volts and ohms
    By dagnasty in forum The FAQ Emporium
    Last Post: 12-30-2005, 11:35 AM
  5. Current draw when PC is off/in hibernation.
    By Arathranar in forum Power Supplies
    Last Post: 01-25-2005, 03:21 PM
